Club323F • View topic - Fan at the radiator Not Spinning when idle
It is currently Sat Nov 07, 2026 1:13 pm
farid
PostPosted: Wed Oct 06, 2004 8:08 am
ok gang...
I have these problem , the fan at the radiator not spinning during idle. when i turned on the aircond, the fan spins. when i drive without an aircond on for about 30 minutes and stop at a traffic light , the temperature start to increase towards nearly high. when the car go uphill (2nd or 3rd gear) , the temperature starts to rise. I have checked the water, the water is ok level( no leaking whatsoever). Before this i also did the flushing method (replace the old with new water) and the result is still the same. It has been running like these for months. othe than replacing the engine what need i to check for? Thanks
PostPosted: Wed Oct 06, 2004 8:11 am
Did you add a decent anti-freeze when you flushed the radiator ?
KBS
PostPosted: Wed Oct 06, 2004 8:17 am
1. try checking the wiring to fan and to wiring harness as it is in an exposed position and corosion can take place, if ok try powering the fan up from a 12v power source( car battery)to check the fan :D
2. check that the thermistor valve is working( take out and put in boiling water to see if valve opens, if not opening go get new one) also remember to get new gasket if taking apart.
John
KBS
PostPosted: Wed Oct 06, 2004 8:55 am
John
farid
PostPosted: Wed Oct 06, 2004 11:05 am
for the decent anti-freeze i have not add yet coz i live in a very hot weather like malaysia. . thanks smotter. kbs how to check this thermistor valve? where this located?
KBS
PostPosted: Wed Oct 06, 2004 11:33 am
usually it is on the engin block where the top hose from radiator connects,
will have to check tonight when i get home as to position of hose and location :)
John
PostPosted: Wed Oct 06, 2004 11:54 am
[quote="farid"]for the decent anti-freeze i have not add yet coz i live in a very hot weather like malaysia. . thanks smotter. kbs how to check this thermistor valve? where this located?[/quote]
Even if it's hot, you must still add antifreeze, as it improves the heat dispersion qualities, protects the water circulation system from corrosion and also lubricates the water pump.
KBS
PostPosted: Wed Oct 06, 2004 12:24 pm
John
Nabeshin
PostPosted: Wed Oct 06, 2004 6:39 pm
dude how has your probelm come along I've the EXCAT same problem!!with mine if you floor it going up hil etc. the temp goes up and returns when you resume 'normal driving'
It all started going funny whne I had my temp sensor replaced by the local garage!!
Any new would be ggrreaaaatttfully appreciated!!
