Club323F • View topic - Front Headlight
It is currently Wed Nov 04, 2026 1:41 pm
Tinnyuk
 Post subject: Front Headlight
PostPosted: Thu Jun 13, 2013 12:11 pm
Ok so the MOT picked up a headlight bulb out, not sidelight or main beam but the headlight. Fitted the new bulb and the insides of the headlight are loose. Can these units be separated so this can be fixed?
Any help appreciated
Justyn
 Post subject: Re: Front Headlight
PostPosted: Thu Jun 13, 2013 1:24 pm
They can yes but it's a bit of hassle having to get the headlight lens off - replacement headlights are easy enough to get hold of from a breaker, and usually not too expensive - makes more sense to do that :thumbleft:
Dale
PostPosted: Thu Jun 13, 2013 5:03 pm
Ive got headlights for sale both types. :D
Tinnyuk
PostPosted: Thu Jun 13, 2013 9:48 pm
Both types?
Dale
PostPosted: Fri Jun 14, 2013 12:47 am
Yes both types. preford are koito and postford are bosh
Tinnyuk
PostPosted: Fri Jun 14, 2013 11:30 am
OK new to this. preford postford?
sorry
Justyn
PostPosted: Fri Jun 14, 2013 11:48 am
Before 1996 is preford, 1996 is a bit of a mix-n-match, 1997 onwards is postford. Ford bought a much larger share of Mazda in 1996, and changed a few bits.
Headlights are a bit different though - Koito headlights are used in all BAs exluding 1998 ones, which use Bosch headlights (clearer lenses, different bulbs, different wiring connectors) :thumbleft:
Tinnyuk
PostPosted: Fri Jun 14, 2013 12:23 pm
ok so advice would be?
I have to change one so should I get two postford lights to make it lighter and brighter or just get the one preford as required.
I have a 1997 'R' plate, so should be a postford car with preford Kioto headlights.
Justyn
PostPosted: Fri Jun 14, 2013 12:47 pm
It won't be lighter and brighter, the lens just looks different - the part that the bulb actually shines through is just flat clear glass on both. Get the preford one as required, otherwise you'll have the headache of chopping off the wiring connectors to get them to fit and work :thumbleft:
And yes, you should have Koito headlights. It will have "Koito" embossed on the lens :thumbleft:
Tinnyuk
PostPosted: Fri Jun 14, 2013 1:00 pm
Thanks for that HughieW.
Benidormdale - how much do you want for the headlight? Plus there is a thread somewhere about an engine swap that I can't find where I spoke about windows. also deleted the email about that thread!
Justyn
PostPosted: Fri Jun 14, 2013 1:04 pm
No problem :thumbleft:
Here's your post about windows, Dale already replied to it :roll: viewtopic.php?f=69&t=55253&p=718635#p718635
Dale
PostPosted: Fri Jun 14, 2013 4:55 pm
[quote="HughieW"]No problem :thumbleft:
Here's your post about windows, Dale already replied to it :roll: viewtopic.php?f=69&t=55253&p=718635#p718635[/quote]
Cheers Hughie,
Just to mention, My first BA was an R reg with Bosch headlights.
Better check just to make sure. As Hughie said it should be stamped on the glass.
You also have a PM :D
