Club323F • View topic - EPC Favours
It is currently Thu Nov 05, 2026 4:42 am
Post new topic Reply to topic  [ 531 posts ]  Go to page Previous  1 ... 13, 14, 15, 16, 17, 18  Next
Stuz
 Post subject: Re: EPC Favours
PostPosted: Wed Feb 02, 2011 1:38 am
I will check tomorrow ;-)
PostPosted: Wed Feb 02, 2011 9:05 am
[quote="TheMAN"][quote="Mark.T"]Cheers KB.
But - to someone with an EPC: are the valve cover gasket part numbers the same?
'95 1.8BA same as '95 1.8 MX5? :)
I'd reload the EPC to my PC, but we're running out of disk space :?
Mark[/quote]
yup same... even the BG one
all of the non-VVT BP valve cover gaskets are the same :)
so that's from 89 up to 2000[/quote]
Weird - the BG has a separate cambelt cover, and looks totally different to the BA and MX5s :shock:
PostPosted: Wed Feb 02, 2011 9:20 am
But the gasket doesn't go around the timing belt bit :)
PostPosted: Wed Feb 02, 2011 10:07 am
No, still surprised they're the same part though, I'm not disbelieving it, it just shocked me :)
PostPosted: Wed Feb 02, 2011 10:25 am
Ahh - the rocker covers are interchangable too :) to an extent anyway - putting a BG rocker cover on a BA leaves your timing belt exposed, and you'd have to cut off and blank the oil breather to get either on an mx5 :evil4:
PostPosted: Wed Feb 02, 2011 10:41 am
I've seen the BG ones on MX5s - done to expose the cam pulleys :)
TheMAN
PostPosted: Wed Feb 02, 2011 10:54 pm
[quote="Stuz"]I will check tomorrow ;-)[/quote]
so it appears my suspicions were correct... I asked my german friend and he did a little searching and found this:
http://www.mazda-forum.info/121-323-626 ... j2003.html
use google translate if you're not good with german ;)
It appears the gasket set you possess is like the FS's gasket kit... it has a new set of intake shutter screws, and all of the gaskets belonging to the intake manifold. :)
since only the european ZM had a VICS system, this kit only is available in europe... but the FS kit (FSY1-13-SRZ) is the same worldwide, and the FS kit comes with a slip of paper with a parts listing inside.
Stuz
PostPosted: Thu Feb 03, 2011 1:18 am
[quote="TheMAN"][quote="Stuz"]I will check tomorrow ;-)[/quote]
since only the european ZM had a VICS system, this kit only is available in europe... but the FS kit (FSY1-13-SRZ) is the same worldwide, and the FS kit comes with a slip of paper with a parts listing inside.[/quote]
Thank you :notworthy:
Simondo
PostPosted: Sat Feb 19, 2011 1:27 pm
Can anyone remind me where we can find that online version of the EPC? :thumbright:
You're welcome.
PostPosted: Sat Feb 19, 2011 1:31 pm
allmazda.net does one - but no pics unless registered
A L 3 X
PostPosted: Sun Feb 20, 2011 10:36 pm
does anyone know whether an engine will be the same as mine from the VIN/engine no.s?
Simondo
PostPosted: Fri Feb 25, 2011 10:17 am
Is there any way of telling how many splines (or just a part number) that my car's CV joints have?
Haribo waiting. Kiddie mix and tangfastics.
You're welcome.
PostPosted: Fri Feb 25, 2011 11:40 am
The pictures on the epc, drawn by Sansitsu Kodorsi aged 8 ¾ arnt clear enough to count splines matey – so its just part numbers :sad:
PostPosted: Fri Feb 25, 2011 11:47 am
Simondo
PostPosted: Fri Feb 25, 2011 4:58 pm
[quote="stuartspel"]The pictures on the epc, drawn by Sansitsu Kodorsi aged 8 ¾ arnt clear enough to count splines matey – so its just part numbers :sad:[/quote]
Thought as much. I'm assuming BAs with 26/24 joints and ones with 26/23 joints would have different part numbers for them. Can anyone tell from my reg what part number I'd need for CV joints? I think it's a long shot since my car was aimed at the JDM.
You're welcome.
Rob
PostPosted: Tue Apr 26, 2011 9:01 am
Can some kind soul please supply pt nos for items 3 & 4 in the diagram on this thread....
[url]http://www.club323f.com/forum/viewtopic.php?f=2&t=45462[/url]
For a pre-ford 1.8 BA, reg N782 TPB
Many thanks.
Rob
TheMAN
PostPosted: Sat Apr 30, 2011 9:57 am
link(r),lateral-rear side
BC1D-28-600B
plate,cam
BCY9-28-6AZ
bolt,adjust
BC1D-28-664
nut
B001-39-037B
Rob
PostPosted: Sat Apr 30, 2011 8:20 pm
Thanks.
marshymob
PostPosted: Wed Jun 22, 2011 11:09 pm
My Car: Julie - 1994 BA
would like a request for removal of the front windscreen
top rubber im after removing so any piccys greatly accepted 8)
PostPosted: Thu Jun 23, 2011 7:37 am
[img]http://i14.photobucket.com/albums/a335/stuartspel/untitled-21.jpg[/img]
Lantis_BA
PostPosted: Tue Jun 28, 2011 4:04 pm
Anyone knows the prices of the screws and plugs needed for stainless steel kickplates?
And if possible including order numbers?
PostPosted: Tue Jun 28, 2011 4:47 pm
Last time I looked I couldnt find SS kickplates :scratch: it just lists the plastic ones.
Lantis_BA
PostPosted: Tue Jun 28, 2011 4:50 pm
I know, but does anyone know the article numbers of these, to order?
dowzerr
PostPosted: Thu Jul 07, 2011 9:55 pm
Anyone got a part number for rear shock absorbers for 1.5 BA?
Debz
PostPosted: Sun Jul 10, 2011 9:53 am
Changing over the manifold on the v6 and would like to know the part number for new gaskets pretty please :D
[img]http://i286.photobucket.com/albums/ll94/chuckles_039/V6/debbie-sig.jpg[/img]
[color=#4000BF]Don't ever tell a woman her place is in the kitchen. That's where the knives are. So, don't piss off the women, men...[/color]
PostPosted: Thu Jul 14, 2011 6:25 am
Dowzerr
[img]http://i14.photobucket.com/albums/a335/stuartspel/untitled-23.jpg[/img]
Debz
[img]http://i14.photobucket.com/albums/a335/stuartspel/untitled-22.jpg[/img]
Debz
PostPosted: Thu Jul 14, 2011 7:58 am
Thankyou Stu :thumbleft:
PostPosted: Sun Aug 14, 2011 2:09 pm
I haven't got access to my EPC at the moment, would someone be able to tell me if it shows bolts?
Need to remove something from under the bonnet and the bolts are rusty, so I'm quite sure they'll snap on removal and I'll be needing new ones.
PostPosted: Sun Aug 14, 2011 2:19 pm
please can some one give me the epc numbers for the gear linkage bushes at the bottom of the gear lever
PostPosted: Mon Aug 15, 2011 8:06 am
[quote="Sloth"]Need to remove something... [/quote]
Mate, there are loads of under bonnet pics, need to know what the 'something' is :D
Egobaker-
[img]http://i14.photobucket.com/albums/a335/stuartspel/untitled-26.jpg[/img]
Users browsing this forum: Google [Bot] and 8 guests
