Club323F • View topic - Steering Rack ??
It is currently Sun Nov 08, 2026 1:23 pm
GavT
 Post subject: Steering Rack ??
PostPosted: Thu May 13, 2004 3:00 pm
Hello
have all models of 323f got the same steering rack ?
i need on for zxi v6
andyj
PostPosted: Thu May 13, 2004 7:52 pm
No. there Not all the same from looking at an mazda epc (mazda price is around £914 +vat for full rack) but you can get some parts seperate ie ball joints £45 seal kit £55 but i would go for a recon unit if i were you . got work out cheaper
mazdaman mazdaspecialist
PostPosted: Fri May 14, 2004 9:16 am
Why do you need new steering rack ?
GavT
PostPosted: Fri May 14, 2004 1:09 pm
Hi mazdaman
got a serious knocking noise wHen i rock tHe steering, so i am guessing its tHe steering rack ??
Stealth
PostPosted: Fri May 14, 2004 1:53 pm
Try your cv joints. may be knackered
GavT
PostPosted: Fri May 14, 2004 2:47 pm
Just stripped both sides bown and un bolted track rod ends.
now when i rock the steering wheel i still get the same knocking noise comming from the steering rack.
when i unbolted the track rod ends, the steering rack that attaches to the track rod ends was totally limp, flopped about with no resistance.
so it looks like a steering rack is going to be needed, got a quote for £125 + vat locally for a recon unit. or £325 + vat fitted.
had a look and it seams to be pretty straight foward (famous last words) done a couple of racks on other cars, fiesta xr2, excort rs turbo. does any one know if this will be as straight foward?
Stealth
PostPosted: Fri May 14, 2004 2:49 pm
It Is based on a ford so It mIght be?
PostPosted: Fri May 14, 2004 8:56 pm
You can buy ends of steering rack seperatlly @55.00 each. easy to do.
cheaper than new rack and less messey
GavT
PostPosted: Fri May 14, 2004 11:46 pm
Hi mate
tHe actual arms tHat tHe track rod fits on to ? How are tHere removed from tHe steering rack, do i just undo tHe gators and pull tHem out ?
any info is appreciated mate, been looking for some parts so i will get in toucH witH you for a quote, ;)
PostPosted: Thu May 20, 2004 9:24 pm
Wheel off. track rod end off & lock nut ( remember to count number of turns on track rod end ) boot off big nut on inside remove and fit new part job done
Users browsing this forum: Google [Bot] and 11 guests
