Club323F • View topic - 1989 323F SE 16v HELP Central locking AND Choke have failed
It is currently Sat Nov 07, 2026 2:45 am
fastbiker
PostPosted: Tue Oct 28, 2003 1:37 pm
Hello
I have an immaculate original pop up headlamp model of the 323F SE 16v
Only problem is that it's central locking and choke have failed.
What relays should I look for perhaps, is the choke vacuum and
electronically operated ie....is there a relay for that ???
Would be nice if it was the same relay that could solve both problems !!!! Help.......There is no manual for this model.
Thanks for your time.
Fastbiker.
Qinx
PostPosted: Tue Oct 28, 2003 5:41 pm
[quote="fastbiker"]Hello
Fastbiker.[/quote]
There is a manual in Dutch for this model, and I think also a haynes (haines?) manuel if I'm not mistaken.
Never knew our (yes, our) model came with manual choke - or aren't you talking about a manual one?
About the central locking: a number of things can be wrong. What doesn't work anymore? If you cannot open or close all four doors by turning the lock on the driver's door, the switch in the door, that's sending a signal to the other three doors, is most likely bust. See if you get any signal on any of the three lock motors in your car when operating the driver's side lock.
Ehhh, I'm talking about this model, the only 323f with pop-ups, so it must kinda look like yours :D
[img]http://members.lycos.nl/qinx323f/images/sideview.jpg[/img]
