Club323F • View topic - waterpump removal
It is currently Tue Nov 10, 2026 9:26 am
astina
 Post subject: waterpump removal
PostPosted: Thu Oct 14, 2004 11:34 am
:D Hi bra.... new here from SA
My baby has been overheating... i took her for a pressure and combustion test. radiator and combustion in fine... what els could coz her to overheat... i think i need to replace to waterpump. anybody got instructions?
:cry:
PostPosted: Thu Oct 14, 2004 11:59 am
Howzit !
I'd suggest you check tuning etc. first - I had the waterpump replaced about a year back, 'cause it was leaking - it cost me R2400.00 ! Although that did include a new cam belt and camshaft oil seals. The water pump doesn't really break - the seals go eventually and then the coolant leaks. By the way, are you maintaining the correct coolant/water ratio in the system ??
astina
PostPosted: Thu Oct 14, 2004 12:27 pm
okay... i is very new to all of this..
i know my water is not leaking out...
what do you mean... water ratio?
is it possible that maybe i need to adjust the tension on the belt?
PostPosted: Thu Oct 14, 2004 12:33 pm
By ratio, I mean there's supposed to be 40% Mazda approced coolant and 60% water in the cooling system.
Does your car overheat all the time, or just when you are in traffic? If it's just in traffic, maybe your fan isn't working ???
astina
PostPosted: Thu Oct 14, 2004 12:37 pm
40% mazda approved coolant.... you mean antifreez..??
its only when i push her to speeds above 110km that the needle shoots up.. i can understand why?
PostPosted: Thu Oct 14, 2004 12:43 pm
Yup - antifreeze !
PS : Whatever you do, don't let her seize - an engine rebuild will cost more than she's worth !!!
astina
PostPosted: Thu Oct 14, 2004 1:02 pm
thanks
PostPosted: Thu Oct 14, 2004 1:25 pm
Or maybe your thermostat isn't working properly ???
astina
PostPosted: Fri Oct 15, 2004 7:14 am
:-)... lol.
i only got your note today...
yesterday i removed the thermostat... and poof. Problem solved.
she runs cooler at high speeds noe.... much better.
thanks for all ya help..
PostPosted: Fri Oct 15, 2004 9:30 am
It's best to install a new thermostat - should only cost a couple of bucks at Midas and will allow your car to warm up far quicker when cold - cold running really speeds up engine wear, 'cause tolerances are set to work when the engine is at optimum operating temperature.
Althaz
PostPosted: Fri May 27, 2005 5:54 pm
Hello,
I'm kind of in trouble : I am stuck with a big overheating problem, cant even do a mile without overheating... I guess the thermostat has got stuck closed. (I hope so, I dont want to pay a new pump).
I have very limited tools where I am and I have to work in the street.. (my other place is about 70miles away) so It would be kind if somewone could tell me exactly where the thermostat is and if I can whip it out quickly without a set of spanners.
Thank's all
Althaz
PostPosted: Sat May 28, 2005 11:57 am
ok, I figured it out first time :D
I found a decent set of tools finally and fixed the problem in a few minutes. (still managed to break an extention... very tight bolt there ;) )
Thx anyway
Bye
essex-lad
PostPosted: Mon May 30, 2005 2:42 am
Welcome to the club Althaz. I am glad you solved your problem :)
