Club323F • View topic - Electric failure
It is currently Sun Nov 08, 2026 10:44 am
_WoLFMaN_
 Post subject: Electric failure
PostPosted: Sat Feb 06, 2021 1:38 pm
Hi there, after sooo much time.
Later I've had some electric problems with the Mazda.
Thing is: The radio stays on, unless I connect something to ground, and the powered rear view mirrors don't work. I know it has to do with some ground cable, but has anyone else had this problem before? Where do you recommend me to check first?
Cheers,
Alex.
 Post subject: Re: Electric failure
PostPosted: Sat Feb 06, 2021 4:01 pm
Online
[quote="_WoLFMaN_"]Hi there, after sooo much time.
Cheers,
Alex.[/quote]
Hi Alex,
I don't know precisely but there is an interesting paragraph in the manual : "If the mirrors do not operate and no sound comes from the electric motors in the mirrors, check the radio fuse in the fuse box" !
So they are linked somehow. I'd start at the the fuse box and trace the relevant earths, also the earth from the mirror switch.
PostPosted: Sat Feb 06, 2021 6:55 pm
Yep, fuse for the radio is not only for the radio!
But the strange behaviour points towards bad grounding somewhere..
_WoLFMaN_
PostPosted: Sat Feb 06, 2021 8:13 pm
[quote="jinglebells"][quote="_WoLFMaN_"]Hi there, after sooo much time.
Cheers,
Alex.[/quote]
Hi Alex,
So they are linked somehow. I'd start at the the fuse box and trace the relevant earths, also the earth from the mirror switch.[/quote]
Thank y'all for fast replying. The thing is: I've checked the grounds for the stuff in the wiring that I did modify, and they are all ok. I'll check the fuses though, I didn't even know there was a fuse for the radio or mirrors lol.
_WoLFMaN_
PostPosted: Sat Feb 06, 2021 10:56 pm
Aighty dudes, it worked. It was the fuse. More than that, I discovered the problem. Turns out that I've bought some multimedia steering buttons that have lights, so I tried to connect the lights to the stock watch, and that blown up the fuse.
PostPosted: Sat Feb 06, 2021 11:03 pm
Be carefull when adding electrical "stuff" to the car.. 8)
_WoLFMaN_
PostPosted: Fri Feb 12, 2021 2:12 pm
I will from now on lol... I have to figure out a way to wire that though..
