It is currently Wed Sep 16, 2026 6:31 pm
luki_92_92
PostPosted: Wed Aug 19, 2015 12:40 pm
At first:
I have mazda 323F BA 1998 year, 1.5 Z5 - "post-lift". I want to swap my engine to BP04 from 323F BA 1996 year. We have problems with wiring ECU.
I have ecu with part numbers:
Z5B3 18 881C
E2T86876M3
There I have two connectors
And on the back of ECU there we have connectors like this:
But in 1.8 one we have ecu like this (upper one):
And the connectors doesn't fit.
So - I need wiring diagrams of ecu pinout in my car 323F BA 1998 - Z5B3 because without this I can't swap engine.
Can anybody help me?
PostPosted: Wed Aug 19, 2015 12:49 pm
The 1.5 ECU won't run the 1.8 engine correctly, various sensors run at different voltages apparently. The easiest option is to get the wiring loom from the 1.8 your engine/ECU came from!
luki_92_92
PostPosted: Wed Aug 19, 2015 1:05 pm
No no no, i don't want to plug ecu from 1.5 to 1.8. I want cut connector from ecu 1.5 cut connectors from ecu 1.8 and plug ecu 1.8 to electric installation in my car because I have another dashboard (post lift) and if I swap all electric then I should swap dashboard but I don't want to do that so I need pinout
PostPosted: Wed Aug 19, 2015 5:40 pm
Dude, prepair your self for a MASSIVE PIE of work!!
Edit: Use Autodata 3.18 or higher..
luki_92_92
PostPosted: Wed Aug 19, 2015 8:42 pm
Unfortunatelly, I have autodata 3.40 and there isn't that ECU, there is only pinout for ecu with 4 connectors but I have only 2 connectors
PostPosted: Wed Aug 19, 2015 9:56 pm
Luki: Read carefully what maZZda says, and I'll say it again for you:
This project will break you!
Best go out and buy another BA, 1.8 or 1.5 whichever you want.
Then...........
Collect up all the bits, wires and plugs and sockets from your old one(s) and ... .take them to the scrappy, be happy!
luki_92_92
PostPosted: Wed Aug 19, 2015 10:15 pm
Blahblahblah, I don't asked for what is better to do... I asked for ecu pinout. If nobody help me I'm gonna step by step do new wiring in my car for 1.8. I have big sentiment for that car and it's impossible to sold that car ever.
So, what about pinout?
HMT
PostPosted: Thu Aug 20, 2015 7:13 am
Cant help with the pinout but you do realize that it really would be a lot easier (plug n play) if you just used a wiring loom and ECU off a facelifted 1.8 ?
PostPosted: Thu Aug 20, 2015 5:27 pm
Dude, i just opened my autodata 3.38 and inside i found the Z5 ecu pinout and there's a flip view of wire side in it so you can follow/find any cable you need.. I don't know where is the problem? :dontknow:
Or am i missing something?
luki_92_92
PostPosted: Thu Aug 20, 2015 7:43 pm
You didn't read that autodata have pinout for pre ford ecu and I have post ford ecu and I have two connectors not four and cable colours are different so I can't do this :/
PostPosted: Fri Aug 21, 2015 9:42 am
I don't think that there's a difference between them..
By memory the second conector was for auto gears so it just falls out of the equation... the 3-th one i'm not sure and have to check.. will see about that..
luki_92_92
PostPosted: Fri Aug 21, 2015 12:15 pm
Oh man, if there isn't difference - what does my topic do there?
Pre-ford - made by denso
Post-ford - made by mitsubishi
Pre-ford - 4 connectors
Post-ford - 2 connectors
Cable colours are different. My 2 connectors fit to 2 slots in pre-ford ecu from 1.5 but pinout is difeerent because in autodata I see that three pins are fit and I have empty slots for wire so if its different rest of wires could be mixed. Connectors in car behind ecu also are different...
If there aren't any differences I should have BP in my car today and not posting requests for pinout for my post-ford ecu.
luki_92_92
PostPosted: Mon Aug 31, 2015 12:21 pm
So, we have 3 wires left to connect BP ecu to connector behind ECU and we don't know what they are for.
Could anybody help us and give us wiring diagrams / ecu pinout for postford ecu Z5B3 (or Z5B5 because I saw that postford cars have this ecu too)?
I know some members of forum have that pinouts/diagrams but nobody want post it, everybody sent it via PM to other members and I can't find anything.
Please help
PostPosted: Mon Aug 31, 2015 1:27 pm
If we had any information that would help you then we would post it.....what would be the benefit for us of not sharing the knowledge?
PostPosted: Mon Aug 31, 2015 8:26 pm
Hi, that's mine Ecu Z5B5
I found that in autodata moust wires don't match, so you're right..
Will try to find some info but not sure.. i'm also interested in the pinout of that ecu..
luki_92_92
PostPosted: Mon Aug 31, 2015 11:26 pm
I have info that ecu with 2 connectors (for example Z5B3 or Yours Z5B5) were installed in cars from Netherlands, but unfortunatelly I don't know NL language, and I tried searching on NL forums but I have no result :cry:
PostPosted: Tue Sep 01, 2015 9:51 pm
Whoop, that's what i found for a 30min. of search for mazda's but don't know if it will help.. so will post it here.. you tell if it helps..
luki_92_92
PostPosted: Wed Sep 02, 2015 1:17 pm
maZZda unfortunatelly this isn't what I need because wiring colours are different and there are some differences too, but mr. Ali sent me wiring diagrams and.... bingo! This is for post-ford with 2 plugs ecu!
You posted that You're interested in wiring diagrams for 2 plugs ecu, so take this
If You need more, check this out
https://www.dropbox.com/s/90xkfsubchkag ... a.rar?dl=0
PostPosted: Wed Sep 02, 2015 7:54 pm
Many,many thanks man!
to mr. Ali too!
luki_92_92
PostPosted: Wed Sep 02, 2015 8:14 pm
Only for mr. Ali, I only reuploaded this on my dropbox ;)
luki_92_92
PostPosted: Thu Sep 03, 2015 8:03 pm
Today engine started :D Now we have cosmetic works and everything will be done :D
Thanks everybody for trying help, thanks mr. Ali :D
PostPosted: Thu Sep 03, 2015 10:32 pm
Post some pictures luki!!
luki_92_92
PostPosted: Fri Sep 04, 2015 12:33 am
When it's done photos will be in topic with my car ;)
luki_92_92
PostPosted: Sat Sep 12, 2015 2:16 pm
More photos here
viewtopic.php?f=14&t=42284&p=745119#p745119
JoaoZinhO86
PostPosted: Mon Apr 14, 2025 11:42 pm
Hello, i have the same swap problem that you have, can you share how you resolve and the electric modifications you done?
thanks
Users browsing this forum: No registered users and 51 guests
