Club323F • View topic - ZXI corner pieces .. removal
It is currently Fri Nov 13, 2026 12:23 am
PostPosted: Thu Dec 15, 2005 6:45 pm
How are the ZXI corner pieces fixed on the front of a ZXI ?? - I had a look the other day got the centre piece off no problem but the sides appear to be riveted on ... then it started raining..
Help appreciated :D
ohh and before anyone asks - this is taking of my donor car to put on Tasha's car, so unfortunately there is not one going spare lol.
PostPosted: Fri Dec 16, 2005 12:36 am
Think they're held on with metal clips and locating pins chap, which will have probably rusted solid, have ye checked the EPC????
PostPosted: Fri Dec 16, 2005 12:37 am
right, checked that, its nuts and bolts mate :D:D
PostPosted: Fri Dec 16, 2005 9:20 am
Thanks Andy, will have another look this weekend, when I tried before it didn't seam like they were bolted on tho, probably have to get it jacked up higher so I can get my head under lol.
will
PostPosted: Fri Dec 16, 2005 11:14 am
Morning
If you are taking about the front corner splitters behind the front wheels then this is what i did the other week.
turn front wheels to one side or the other to give your self more room to work
there are i think two plastic screw/ pop out things a single screw and a bolt that all need to be undone. make sure you get a good fit on the plastic bits, i managed to strip the head out of one as the plastic is quite soft.
they will be full of crap!
if you are putting them onto another car it might be worth undoing a couple of the screws/ plastic things that hold the front wheel arch liner in place and checking that the drain hole between the chassis/ firewall and the front wong is clear. i took mine off to check it and spent 10 mins cleaning it out with the aid of the garden hose! (both sides) think this was where water had been building up and then leaking into the cabin from!
hope this is of use and sorry for rambling!
PostPosted: Fri Dec 16, 2005 10:38 pm
Cheers lads got them off tonight along with the side skirts ... each side was attached with 5 x 10mm nuts :D
