Club323F • View topic - Best way of securing an amplifier in the boot?
It is currently Mon Nov 09, 2026 1:05 pm
PostPosted: Fri Feb 18, 2011 11:08 pm
As per the question. I haven't got a false floor, and don't really want one again.
My amp also doesn't appear to have any mounting holes, so I would need to do something about that.
Go!
molestrangler
PostPosted: Fri Feb 18, 2011 11:57 pm
go to a diy store and see if they sell those strips that look like meccano,fashion a couple of straps find a mounting point in boot mount amp and wire tralaa. sorry not a lot of help!!
lewp91
PostPosted: Sat Feb 19, 2011 11:45 am
velcro!
works really well :P
make sure it has ventilation.. what amp is it and what sub (if any) how big is the box?
MrKikker
PostPosted: Mon Feb 28, 2011 5:28 pm
mount it to the back of the backseats?
PostPosted: Mon Feb 28, 2011 5:32 pm
[quote="MrKikker"]mount it to the back of the backseats?[/quote]
Thats where I'm planning to put it, but not sure by what means yet. No mounting holes on it, so other than velcro I'm kind of out of ideas.
lewp91
PostPosted: Mon Feb 28, 2011 5:48 pm
Small ratchet straps screwed under :)
MrKikker
PostPosted: Tue Mar 01, 2011 11:41 am
[quote="Sloth"][quote="MrKikker"]mount it to the back of the backseats?[/quote]
Thats where I'm planning to put it, but not sure by what means yet. No mounting holes on it, so other than velcro I'm kind of out of ideas.[/quote]
edit - didn't read proper
velcro might do, otherwise secure it with straps?
PostPosted: Tue Mar 01, 2011 1:26 pm
[quote="Sloth"]
I've had it apart to repair it too, and theres no way I can add holes :(
Depending on how well (or not) the amp performs I may replace it anyway and this time I'll make sure I get one with holes in. Otherwise yeah, I'd just screw it down into the metal of the back seats.
PostPosted: Tue Mar 01, 2011 1:44 pm
You can get heavy duty hook & loop fastener - it's pretty good stuff :)
tarkoon
PostPosted: Sun Mar 13, 2011 5:04 am
you can put mdf board on floor and stick velcro to secure between floor mat and underside of mdf panel
poweramp can fixed to mdf panel by normal screws
klunkeh
PostPosted: Thu May 12, 2011 4:27 am
Well you could do what I did. Just mounted two amps upside down on the bottom of the parcel shelf. Works a charm ;)
paul323f
PostPosted: Thu May 12, 2011 4:05 pm
You sure there no mounting holes? Some amps have little n shaped cut outs on the edges?
PostPosted: Thu May 12, 2011 5:01 pm
No holes at all, its a good 10-15 years old this thing and I can only assume it had some kind of metal or plastic bracket that went with it originally.
Few days after posting this thread up I just sat it in the boot, and its remained in place ever since, not exactly elegant but hey. Expected it to slide about all over the place but seems okay.
