Club323F • View topic - Throttle Body Coolant Bypass
It is currently Thu Nov 05, 2026 7:07 am
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2
lewp91
PostPosted: Tue May 03, 2011 3:36 pm
idea: now run a separate coolant system with an oil cooler and small inline motor.. pump coooollldd fluid through it?
doubt the performance will weigh out the extra weight added.. however the air sensor if a hot wire system (new type) (pretty sure these engines are too old) monitor air temp and density aswell ;)
MrKikker
PostPosted: Fri May 06, 2011 8:52 pm
[quote="Roc"] only an issue at cold temps really.
.[/quote]
not a problem in the summer I reckon?
cosmos1989
PostPosted: Sun May 08, 2011 7:40 pm
Right so out with the new and back in with the old.
I put the tubes back and noticed an instant improvement in my idle, it's back to normal, also not really noticed any difference in performance either it's a little smootheras well, ah well we tried!
Before anyone comes back telling me it's not what's happened to them this was MY experience with MY car.
PostPosted: Sun May 08, 2011 7:45 pm
[quote="cosmos1989"]Before anyone comes back telling me it's not what's happened to them this was MY experience with MY car.[/quote]
I gained 30 bhp doing mine ;)
MrKikker
PostPosted: Sun May 08, 2011 8:10 pm
did this yesterday, no problems with idle or whatsoever..
PostPosted: Sun May 08, 2011 8:40 pm
Mine is back to normal, but it didn't fix my hesitation symptoms :scratch: I've figured out, it only does it after starting the engine when it's already warm. Putting the clutch in, giving it a rev, then driving normally cures it :scratch:
Glad to hear yours is back to normal again Porl :thumbleft:
cosmos1989
PostPosted: Sun May 08, 2011 9:52 pm
[quote="DMS"][quote="cosmos1989"]Before anyone comes back telling me it's not what's happened to them this was MY experience with MY car.[/quote]
I gained 30 bhp doing mine ;)[/quote]
[img]http://i907.photobucket.com/albums/ac276/Xino_Fox/MEGAMEME.jpg[/img]
And Cheers huggles, might be a difference between the engine sizes, what with Daz gaining an extra 30bhp and all ;)
PostPosted: Sun May 08, 2011 9:53 pm
[quote="cosmos1989"][quote="DMS"][quote="cosmos1989"]Before anyone comes back telling me it's not what's happened to them this was MY experience with MY car.[/quote]
[img]http://i907.photobucket.com/albums/ac276/Xino_Fox/MEGAMEME.jpg[/img][/quote]
lewp91
PostPosted: Mon May 09, 2011 7:06 am
your hesitation might be down to your idle needing adjustment?
i assume you've already done the gnd-ten trick? maybe it'ts time to play about with the TB?
however firstly i would say clean everything like sensors, maybe even take the TB off and hose it in brake cleaner? something might be slightly sticky?
PostPosted: Mon May 09, 2011 8:07 am
Already adjusted the idle, throttle body is already clean (cleaned it up not long ago).
I plan to remove the IAC and check that on a multimeter at some point this week.
MrKikker
PostPosted: Mon May 09, 2011 9:14 am
this morning noticed that the idle was a tad high. personally i thing it's because the choke is kept open longer because without the coolant passing through the throttle body, the IAC takes longer to warm up.
however, didn't notice any performance decrease (or increase for that matter :lol: ), but the little things make the difference!
Roc
PostPosted: Mon May 09, 2011 9:29 am
[quote="MrKikker"]this morning noticed that the idle was a tad high. personally i thing it's because the choke is kept open longer because without the coolant passing through the throttle body, the IAC takes longer to warm up.
however, didn't notice any performance decrease (or increase for that matter :lol: ), but the little things make the difference![/quote]
The coolant warms the IAC yep, wait until a cold winter morning, it'll be activated for a very long time. The reason I removed this mod from my car.
MrKikker
PostPosted: Mon May 09, 2011 10:07 am
[quote="Roc"][quote="MrKikker"]this morning noticed that the idle was a tad high. personally i thing it's because the choke is kept open longer because without the coolant passing through the throttle body, the IAC takes longer to warm up.
The coolant warms the IAC yep, wait until a cold winter morning, it'll be activated for a very long time. The reason I removed this mod from my car.[/quote]
when the cold season is coming i'll put the hose back, until then I'm fine with it ;)
PostPosted: Thu May 12, 2011 12:01 am
Done this on my V6, as its been running a touch hot. The V6 the water pipe comes from the rear cylinder head, to the front side of the TB, then another pipe heads to the EGR valve to do what ever it does there (heat it up or cool it down anyone?). So simple mod is take pipe from cylinder head, and connect direct to the EGR valve.
Took 3-5 attempts of setting the idle but finally got it running fine now. Initially the usual idle problems arose - too low, then too high. You can cure this with the ten + GND idle setup although it does take 3 or more attempts.
Runs well, easy to put back in the winter.
marshymob
PostPosted: Thu May 12, 2011 10:37 pm
My Car: Julie - 1994 BA
fastmike, would this work with an auto, just wondering as the iac valve on cols has given up
simple fix if it is then i hope 8)
PostPosted: Fri May 13, 2011 12:07 am
Don't know. What do auto throttles look like?
marshymob
PostPosted: Fri May 13, 2011 9:07 pm
will get col to get a photo :lol:
could be a while though 8)
johnny14
PostPosted: Thu Jul 19, 2012 6:20 pm
I found it logical mates, and I was desided to gave it a try! This days in Greece the temperature is around 40*C so the results whould be seen from the first kms! So after a month, I see no perfections... Only more time to rich the engine's working temperature with a result? More fuel consumption with no reason. I think it's only a waste of time mates!!!
properbowen
PostPosted: Tue Aug 07, 2012 3:22 pm
while i was polishing my throttle body i thought i'd take some pics of the manifold to help clear things up...
[img]http://i75.photobucket.com/albums/i320/properbowen/tbmanif.jpg[/img]
[img]http://i75.photobucket.com/albums/i320/properbowen/tbmanif_coloured.jpg[/img]
i dont know much about the workings but the manifold seems to be split into 4 isolated cells.
yellow - engine side air
green - intake side air
blue - oil?
red - coolant.
as you can see the coolant cell is so small it probably wont have much of an affect after the oil warms up...
i'm guessing the IAC motor adjusts flow between green and yellow cells to control the idle? but im not sure of the purpose of the oil and water. there does seem to be another motor/valve/sensor/something in the coolant and oil cells. does this control another valve to control cold idle?
[img]http://i75.photobucket.com/albums/i320/properbowen/Car/IMG_07645.jpg[/img]
PostPosted: Tue Aug 07, 2012 10:37 pm
Forgive my blunt reply as i am on my phone but there is no oil feed going too or from the throttle body
properbowen
PostPosted: Wed Aug 08, 2012 9:15 am
i thought that hence the ? after the oil but it seemed very oily in that chamber. picture is after i've cleaned it a little (the coolant chamber had those red crystals i've seen around a coolant leak)
Users browsing this forum: Bing [Bot] and 1 guest
