Club323F • View topic - Air Condition Compressor
It is currently Tue Nov 10, 2026 8:49 am
drunkenmunky
 Post subject: Air Condition Compressor
PostPosted: Wed Aug 03, 2005 9:58 am
The compressor of my air condition is faulty and needs to be replaced. Can someone tell me from where I can find a second hand one or maybe some compressor at a reasonable price? In the country where I live there are only 10 cars like mine so it's impossible to find one here...
thanks :alien:
PostPosted: Wed Aug 03, 2005 8:58 pm
Is there any scrap yards.
PostPosted: Wed Aug 03, 2005 10:04 pm
[color=blue]Is there any chance that other Mazda's share the same compressor? May even be other manufacturers too......[/color]
drunkenmunky
PostPosted: Thu Aug 04, 2005 8:32 am
Good question Steve. In fact I'd really appreciate if somebody can answer this question please!!
PostPosted: Thu Aug 04, 2005 8:42 am
These guys look good (Bristol Car Aircon) ...
--- http://www.carairconparts.co.uk/14928/18601.html
I was thinking - you may be able to replace yours with a more modern one which could be lighter yet more efficient ???
drunkenmunky
PostPosted: Thu Aug 04, 2005 8:51 am
I've sent them an email requesting availability and price. Will followup on this thread.
drunkenmunky
PostPosted: Thu Aug 04, 2005 9:41 am
No units are available in the UK :(
PostPosted: Thu Aug 04, 2005 10:00 am
[quote="drunkenmunky"]No units are available in the UK :([/quote]
Silly sods ...
drunkenmunky
PostPosted: Fri Aug 05, 2005 9:02 am
At the moment i want to remove the fuse of the AC so noone will switch it on again until repaired. I took a glimpse at the GUIDE section and viewed 'the definite guide of fuses'. Have I understood well or there are supposed to be two fuse boxes - the main and the interior? I have only seen one and which does not correspond to the one which contains the fuse of the AC. Can someone tell me where is the INTERIOR fuse box?! :bounce:
PostPosted: Fri Aug 05, 2005 10:26 am
Mine's in the driver's side footwell, inside the plastic trim by your right foot ...
drunkenmunky
PostPosted: Sat Aug 06, 2005 3:06 am
OK found it. By the way, fuses are supposed to be removed by pulling them, or is there some clip which needs to be pressed? I was working in a dim light environment so i need to check it tomorrow morning, but it gave me a hard time to pull the fuse, without succeeding.
Dragon Rob
PostPosted: Sat Aug 06, 2005 8:56 am
There should be a little pair of tweezers on the back of the fuse box cover which you use to grab the fuses (otherwise they are a pain to get out) :thumbright:
Full Circle:-
PostPosted: Sun Aug 07, 2005 11:26 am
I use long nose pliers - works better than the tweezers !
drunkenmunky
PostPosted: Tue Aug 09, 2005 9:24 am
OK Got the fuse out (however removing the A/C fuse will also disable the blower, so i plugged it in again). If I remove the compressor, and I accidentally switch on the A/C, will that make any damage to the car?
PostPosted: Tue Aug 09, 2005 9:08 pm
I doubt it - the switch is electrical - if the compressor is removed, I doubt the current will reach it - just make sure the wires are insulated ......
