Club323F • View topic - eney one no where i can find inlet air temp sensor
It is currently Fri Nov 06, 2026 12:22 pm
1500ccgxi1998mazda
PostPosted: Sun May 24, 2009 9:23 pm
hi
can eney one help me and let me no where the Inlet Air Temp sensor is thanks
steven
PostPosted: Sun May 24, 2009 10:10 pm
My Car: 1998 Imola
its the part that looks like a little cone that plugs into your induction kit.
Look at the pic, see where the induction kit is, the black rectangle connected to it is the housing here the normal sensor and the temp sensor is. Look at the wires mate. Hope this helps.
[img]http://i494.photobucket.com/albums/rr305/swelch29/IK.jpg[/img]
steven
PostPosted: Sun May 24, 2009 10:12 pm
My Car: 1998 Imola
is it the piggy back sensor thing you are putting into the car? The little 1k resistor?
1500ccgxi1998mazda
PostPosted: Mon May 25, 2009 2:03 pm
yes it is not sure how to fit it
offshore4ft
PostPosted: Mon May 25, 2009 2:07 pm
Don't do it. Waste of time. Apparently all they do is fool your engine into thinking its running cold, therefore making it run richer in fuel. Possibly causing long term damage/unnecessary strain to the engine with next to no power increase at all ;)
offshore4ft
PostPosted: Mon May 25, 2009 2:09 pm
But if you do decide to go for it... the air temp sensor connection goes onto the MAF (follow the group of wires between the coolant reservoir and the battery) :lol:
steven
PostPosted: Mon May 25, 2009 5:53 pm
My Car: 1998 Imola
I would advise you not to do it, it does make a slight difference in performance but IT SLOWLY KILLS your engine. Expect about 10 to 20% of your engine life to dissapear. Its not a natural mod, if it was supposed to be like that all cars would have it as standard. As Scott says it fools the engine into thinking the air that is coming in is cold.
Eire323f
PostPosted: Tue May 26, 2009 12:38 am
Yep, you can expect pitted valves at the very least from what I've been told as it make the car run rich with the timing advanced. For the small gain in performance its really not worth wrecking your engine.
