Club323F • View topic - Clutch Change
It is currently Wed Nov 11, 2026 2:30 am
Arnie
 Post subject: Clutch Change
PostPosted: Fri Apr 08, 2005 3:24 pm
Anybody done this, do you need to remove passenger drive shaft.
PostPosted: Sun Apr 10, 2005 3:22 pm
You have to remove the passenger side drive shaft from the box, you may get away with leaving hanging out of the wheel bearing if you can get enough room. I normally take the whole left hand knuckle off and be done with it because 9 times out of 10 the shaft will be stuck fast in the hub :(
Arnie
PostPosted: Sun Apr 10, 2005 7:15 pm
Thanks Robbie
Do you mean the bolts holding it to the strut.
Is it just a case of pulling the shaft off the diff, or tapping it off with a hammer.
what about lining the plate up, is it straightforward enough.
PostPosted: Mon Apr 11, 2005 12:02 am
Yeah, remove the track rod end, remove the 2 17mm bolts where the knuckle is bolted to the shocker and the 2 17mm where the knuckle is bolted to the lower arm. The drive shaft can be "popped" out of the diff with a pry bar. Either align the clutch disc by eye or use an aligning tool 8) Not a job I'd relish doing on axle stands :?
Arnie
PostPosted: Mon Apr 11, 2005 9:45 am
thanx Robbie, clutch should be nearly gone now after 189k, but not slipping yet.
PostPosted: Sat Apr 16, 2005 11:44 am
You make it sound simple Robbie, is it just a case of seperating the engine and gearbox in situ enough to remove the clutch from the engine?
Found a clutch being sold new for 78.91 + VAT.
PostPosted: Fri Apr 22, 2005 11:23 pm
You have to seperate the engine and gearbox and put the gear box on the floor 8) It is simple...... with the right tools/experience :wink:
