Club323F • View topic - central locking trigger?
It is currently Tue Nov 10, 2026 3:29 am
voyager0uk
 Post subject: central locking trigger?
PostPosted: Thu Mar 31, 2005 4:53 pm
hi, could anyone shine any info onto what sort of trigger a 95 1.5gli has? i have a choice of 4 types.....negative trigger positive trigger pos/neg or pneumatic trigger. its so i can wire up c/locking to an alarm. cheer for any help.
[img]http://img.photobucket.com/albums/v214/voyager0uk/locking.jpg[/img]
JAJC82
PostPosted: Thu Mar 31, 2005 6:50 pm
When I fitted my remote locking I had the choice of earth switched, positive switched and pneumatic switched. I phoned sparkrite and they said it was earth switched, connected it up and it works fine. I have a 1997 1.5.
I hope this helps.
voyager0uk
PostPosted: Thu Mar 31, 2005 7:49 pm
where did you wire it into? the wires that go to to the drivers door lock or somewhere else?
JAJC82
PostPosted: Thu Mar 31, 2005 8:15 pm
I found the wires behind the lower kick panel on the passenger side of the car, (if you sit in the passenger seat it is the first plastic panel infront of the door by your left foot). The 2 wires are green/red and green/white. I would think it should be the same on yours. There was even a bolt in the footwell to fit the control unit to. :chain:
voyager0uk
PostPosted: Thu Mar 31, 2005 8:25 pm
top man, may your 323 run forever. thanks
foye
PostPosted: Wed May 04, 2005 11:58 pm
my cdl fuse 30amp keeps blowing when i try to connect my meta cdl unit to the wires above. I got the meta cdl setup to send Earth\Negative commands. I checked the green/white wire with a meter it showed 12v positive is this right? the red/white wire didnt show anything. I'm assuming the negative commands being sent is shorting the fues when connected to the green/white wire. Please i neeeeed help.
JAJC82
PostPosted: Thu May 05, 2005 9:30 pm
Not sure why it should be blowing the fuse. :? The two wires that you need to look for are green/red and green/white, you have put red/white wire so you could be looking at the wrong one. One controls the open and the other close.
If you still have probs it might pay to ring the makers of the unit and they should be able to help. I phoned sparkrite and they were very helpful, just had to tell them the make and model of the car and they told me which wires to connect.
foye
PostPosted: Fri May 06, 2005 12:15 am
ooops meant to say green/red anyways thanks for your reply JaJ i'll give meta a call see what say.
