Club323F • View topic - Speaker size?
It is currently Sat Nov 07, 2026 12:23 pm
bassoctopus
 Post subject: Speaker size?
PostPosted: Thu Oct 23, 2003 7:31 pm
What is the size of the front door speakers? I just want to slot an Alpine 2 way straight in as the originals are terrible. The grilles look like 6x9s but I'm sure they're not.
Also can anyone give me a quick guide to removing the door trims so I can replace the speaker.
Neil
Toyboy
PostPosted: Fri Oct 24, 2003 4:23 am
The front door speakers are 5x7inch,the trims arnt that hard to get off,its mainly clips and a few screws depending on the model you have :wink:
lethal323
PostPosted: Fri Oct 24, 2003 11:58 am
there is no problem fitting a 6*9 there, i just trimmed it a littlebit then i put an anti rusting resedo on it and voila, just make new screw holes to screw the speaker in, just dont get a 6*9 wit an too big magnet, it will hit the window when its down
bassoctopus
PostPosted: Fri Oct 24, 2003 5:17 pm
Thanks for your help.
Asked my local car hifi specialists (good install dept, average sales) about this and was told that there wasn't a straight swap available. I would need an adapter that would allow me to fit a 13cm speaker (sounds a bit small to me).
I don't want massive volume, I've got a decent Alpine head unit/changer and just want something that will sound ok. I don't want to spend more than £50-£60 on the speakers and would ideally want a trouble free installation - although I don't mind drilling some holes for compnent tweeters if necessary.
Any ideas on a semi decent straight swap speaker?
Thanks again
Neil
Daniel
PostPosted: Sun Oct 26, 2003 8:50 pm
Better use ovals to get a bit more bass from the doors. I have Caliber competition series 5"x7" and they aren't expensive and fit nicely. Some owners would want to use sound deadening materials in the doors for a better sound.
Guest
PostPosted: Wed Nov 12, 2003 12:28 pm
does anyone know the size of the back door speakers as well ?
Dogo
PostPosted: Fri Nov 14, 2003 2:20 am
6" i believe. maybe 6.5"
Captain Phil
PostPosted: Tue Dec 02, 2003 8:19 pm
The ones in the rear doors a 5" 1/4 inch, I know because i ordered the wrong ones for mine!!! I have a set of infinity 5 x7s (front doors) for sale if anyones interested!!
dave
 Post subject: Hi
PostPosted: Wed Dec 31, 2003 2:40 am
Hi
What infinities are they and how much you want for them?
Im trying to get the correct size speakers for my back doors at the mo. I've got a 1997 323 estoril. Dont know if that makes any difference or if the sizes are generic to all models. You think that they would be 5 1/4 too?
Captain Phil
 Post subject: Speakers
PostPosted: Sun Jan 04, 2004 9:40 pm
I'll let the speakers go for £30 + whatever the postage is.
They're still sealed in the box!
The model No is: 6802CF, 60Watt and 180Watt Peak. I think all that generation of 323s had the same size speakers in the doors. Mines a 97' ZXi
I still haven't got round to getting the replacement 5'1/4 for the rear! :oops:
PostPosted: Fri Mar 19, 2004 3:28 pm
Ok Ok I think I am getting there with the speakers etc....
But....... can anyone tell me what the maximum depth I can have for the front speakers so that they don't foul the window when it comes down ?
Please someone must know, I have seen some nice 5 x 7's and the depth is about 56mm, I guess that should be fine :S what you reckon ?
Stealth
PostPosted: Fri Mar 19, 2004 4:29 pm
i reckon that if you already have them, go and fit them. Then see if the window knocks. If it does, space the speaker out with washers.
droopy673
PostPosted: Fri Mar 19, 2004 11:56 pm
I measuered them. You can get away with a 2 1/2 inch depth, from the back of the cage to the rear of the magnet. As a stop gap I've slotted in some 6 inch rounds, surprising the amount of space behind the door car!
PostPosted: Sat Mar 20, 2004 12:06 am
Well I ordered them, will let you know how I get on 8)
Thanks Droopy, sounds like it should fit then, hopefully they will arrive next week and can be fitted next weekend, weather permitting.
