Club323F • View topic - Charged V6
It is currently Thu Nov 05, 2026 2:21 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2  Next
Jody
 Post subject: Charged V6
PostPosted: Wed Jul 22, 2009 2:08 pm
[img]http://i137.photobucket.com/albums/q204/1997KLDE/S1030405.jpg[/img]
[img]http://i137.photobucket.com/albums/q204/1997KLDE/S1030404.jpg[/img]
[img]http://i137.photobucket.com/albums/q204/1997KLDE/DSCN0038.jpg[/img]
Nice install!!
Kits available from the states using a Mini S charger
Who's having a go first :badgrin:
manwell68
PostPosted: Wed Jul 22, 2009 2:14 pm
I asked about the possibility of this some time ago and was laughed at :( but now who's laughing. Ha ha ha. Anyway enough of that. If someone is out there with the mechanical know how to install this piece of wonderous technology I will pay to have it done to my motor.
PostPosted: Wed Jul 22, 2009 2:33 pm
Any links? :)
Squidy
PostPosted: Wed Jul 22, 2009 2:54 pm
Not sure, but that engine bay looks wider than ours? I'd love to see it in action though and what gains there'd be...
Jody
PostPosted: Wed Jul 22, 2009 3:11 pm
http://www.mx6.com/forums/2g-mx6-forced ... tup-9.html
Not had chance to read it yet as I am at work. Cant find any direct links to the kit but it looks reasonable to knock up.
Apparently the only thing holding most S/C Mazda V6's back was the bearings used for the transfer shaft as they would overheat and melt when going over 4k.
http://detroit.craigslist.org/pts/1238961110.html - Cheap turbo kit for V6 also
Jody
PostPosted: Wed Jul 22, 2009 3:26 pm
[quote="Squidy"]Not sure, but that engine bay looks wider than ours? I'd love to see it in action though and what gains there'd be...[/quote]
Look for the charged MX-3 V6 on Youtube. 2.5 KLDE I think and it goes like stink.
Definitely enough room for a charger under the 323f bonnet. My mates just put one on his 1310cc Mini .
Patrick323
PostPosted: Wed Jul 22, 2009 4:31 pm
when you relocate the battery and the fusebox + coolant tank there definatly will be enough room for that hairblower :D
offshore4ft
PostPosted: Wed Jul 22, 2009 6:00 pm
Mmmmmmmmmm
nat1979
PostPosted: Wed Jul 22, 2009 6:16 pm
my mate had a look under my bonnet and thats the first thing he said, "theres loads of room in there, fling a blower in there lol"
Murray
PostPosted: Wed Jul 22, 2009 6:46 pm
that doesn't look to hard to install! hows the fueling side of things coped with?
diy outside of the kit?
[img]http://i210.photobucket.com/albums/bb192/Muz1986/Neilyabl00dyedjit.jpg[/img]
Kash
PostPosted: Wed Jul 22, 2009 10:30 pm
Someone do it man! & Murray ya chav, :lol: @ your avatar.
PostPosted: Thu Jul 23, 2009 8:51 am
I saw that quite a while ago. The problem would be getting it into the BA engine bay .... I don't know the dimensions, so you never know ;)
You'd need a different air intake!
Kash
PostPosted: Thu Jul 23, 2009 12:10 pm
Looks like you would have to move the, battery and waterbottle? Intake could go in the wing? Or maybe not because all V6s have air con?
Jody
PostPosted: Thu Jul 23, 2009 12:37 pm
[img]http://photos-a.ak.fbcdn.net/photos-ak-snc1/v2930/250/74/511818684/n511818684_1573616_5906687.jpg[/img]
M45 Eaton on my mates Mini. 180BHP Using a suck through rather than blow through fuelling.
It will easily fit an F engine bay with maximum length including pulley of 37cm. The F has around 49cm from Dizzy. Change the snout for one of these and its nearer the 27cm at smallest spec! Leaving loads of room!
http://cgi.ebay.com/ebaymotors/02-05-1- ... ccessories
Height is 12.5cm and width is 18cm. So all dimensions easily within spec.
Air intake would run to the inner wing as per pictures and the charge would go through a short pipe to the t.b. with the all important blow off valve attached.
Fuelling would be sorted with the boost adjustable FPR but you will need a S-AFC to fine tune and also over-rule the o2 sensors.
Probably get away with leaving the battery where it is as there should be ample room and just move the header tank.
Only thing that you cant easily adjust and work out is the drive pulley to s/c pulley ratio to get the right boost levels.
Ditch the A/C :badgrin:
£150 for charger
http://cgi.ebay.co.uk/Eaton-M45-Superch ... 1|294%3A50
Kash
PostPosted: Thu Jul 23, 2009 2:24 pm
when you doing it then mate? ive got a feeling Dan aka GOGO is doing something....Gone rather quiet these days.
Ringo
PostPosted: Thu Jul 23, 2009 3:30 pm
[quote="manwell68"]I asked about the possibility of this some time ago and was laughed at :( but now who's laughing. Ha ha ha. Anyway enough of that. If someone is out there with the mechanical know how to install this piece of wonderous technology I will pay to have it done to my motor.[/quote]
Small minded-ness see Rob (not you by the way, lol), anything is achievable!
You'd be best of approaching a tuning company, or motorsports garage or something like that though man, even if someone you knew had the mechanical know how, you'd have alot of niggles that would need to be sorted throughout I reckon, plus you'd need a re-mappable ECU which would need mapping.
But go for it man....I wanna see a noble green BA running a supercharged engine screamin around Castle Combe next year!!!!
manwell68
PostPosted: Thu Jul 23, 2009 7:48 pm
Ringo thats all I needed. Your belief in me brightens my day. Now i've got to persuade Kim to let me take money out of the wedding fund.
PostPosted: Thu Jul 23, 2009 9:14 pm
[quote="Jody"][quote="Squidy"]Not sure, but that engine bay looks wider than ours? I'd love to see it in action though and what gains there'd be...[/quote]
Definitely enough room for a charger under the 323f bonnet. My mates just put one on his 1310cc Mini .[/quote]
I don't think so, how are you going to get the pully spinning? the blets are on the wrong side on a 1.5, believe me, I looked into this 3 years ago, even offered up the Mini charger, it won;t fit, there's NOT enough room, even if there were, you've still got to drive it somehow and the only thing I could come up with was a shaft across the front of the engine!
There is a solution, but I'm still working on it ;)
Murray
PostPosted: Thu Jul 23, 2009 9:41 pm
[quote="andym323"][quote="Jody"][quote="Squidy"]Not sure, but that engine bay looks wider than ours? I'd love to see it in action though and what gains there'd be...[/quote]
There is a solution, but I'm still working on it ;)[/quote]
am i missing something or are there no pictures above? :lol:
theres the solution! :p
nat1979
PostPosted: Fri Jul 24, 2009 12:14 am
yeah the pic has a pully shaft in it
PostPosted: Fri Jul 24, 2009 12:38 am
The Probe is wider than the F though, I'd love to see it work, I've been thinking about charging my F for several years, but I just think the Mini charger is too big for an F.
What I want is a small charger, preferably with an electronic clutch that can be mounted where the aircon pump would go on a custom billet bracket. I'd also add a fifth injector and an Aquamist controller to make it all work :D
I've a couple of chargers in mind but one is over £2500 and the other is rare as rocking horse poo :P
PostPosted: Fri Jul 24, 2009 1:25 pm
My Car: Mazda 323F GTR
ROTREX C15-60?
:P
we're looking as well!
vmansmx5
 Post subject: Re: Charged V6
PostPosted: Fri Apr 27, 2012 9:00 pm
Hay guys im so thinking about putting a supercharger on my V6 it so can be done i removed all the aircon crap and mite set it up there.
Have you seen my Custom turbo mx5 that turbo setup i done myself so ill give this a go just need 2 save some money then ill give it a crack :D :D :D :D
PostPosted: Fri Apr 27, 2012 9:46 pm
it has been done before. there is a guy in Ireland who did it to a KLZE in an mx3... there are videos on youtube of it
morgiboy
PostPosted: Thu May 17, 2012 8:48 pm
it may be worth looking into a engine from a MAZDA XEDOS 9 2.3 V6 MILLER SUPERCHARGED dont know if it will fit but if it did you would have one fast ba :badgrin:
RHRH
PostPosted: Wed Jul 11, 2012 7:33 pm
It won't fit, the miller is quite large...
PostPosted: Wed Jul 11, 2012 9:15 pm
[quote="RHRH"]It won't fit, the miller is quite large...[/quote]
Not quite true. The only difference size wise is the rear head is designed slightly differently to fit the surcharger between the v. This fouls the brake servo but you could use a remote brake servo kit and that should give you enough space
morgiboy
PostPosted: Wed Jul 11, 2012 10:25 pm
[quote="eogbaker"][quote="RHRH"]It won't fit, the miller is quite large...[/quote]
Not quite true. The only difference size wise is the rear head is designed slightly differently to fit the surcharger between the v. This fouls the brake servo but you could use a remote brake servo kit and that should give you enough space[/quote]
and at a guess you have really looked into this amazing idea :D
PostPosted: Wed Jul 11, 2012 11:21 pm
i kind of did lol... i was wanting to fit the charger onto my engine but it definitely wont fit with out changing the heads which i definitely dont want to do lol
PostPosted: Mon Jul 16, 2012 2:40 pm
It's not the position of the rear head that is different, it is pretty much the same head, the difference is the cam pulley, instead of being driven from the intake cam it is driven off the exhaust cam which makes the engine look HUGE, this however WILL foul our RHD master cylinder and servo arrangement, if you had a LHD car however. . . .
