Club323F • View topic - Remove front hub
It is currently Sat Nov 07, 2026 7:03 am
Rizzi1
 Post subject: Remove front hub
PostPosted: Wed Aug 28, 2013 3:38 pm
Hello been trying to get hub off drive shaft to change cv boot but it just isn't happening, already snapped an hub puller :evil: tried suggestions on forum but no joy, anybody got any other ideas how to separate, as I'm getting to the stage were I will scrap the car. 1 very angry person lol :?
sneakz
 Post subject: Re: Remove front hub
PostPosted: Wed Aug 28, 2013 9:48 pm
For me it was just undo the big bolt, a small block of wood and a hammer. It came out quite easy both times.
Dale
PostPosted: Wed Aug 28, 2013 10:17 pm
Hi mate and welcome :D
All 3 of my BA's have came out with no problem, however when I was removing the CV joints from the hub on my breaker I found them to be impossible to remove. :(
In the end I had to use the power of my hand and brute force (sorry that didn't sound right) :lol: but you get what I mean, get a mallet and smack it till it pops out. and it will. :)
You might damage the front of the CV joint and as a result you wont get the hub nut back on, so you will need to buy another CV joint (£20/£30) but you normally get a new boot and hub nut with them.
If you do bugger it and have to buy a new joint put a little bit of grease around the teeth of the joint so that it slides on easy and wont seize in the future when you remove it.
Also do this if you manage to get it off.
Hope this helps :D :D
Roc
PostPosted: Wed Aug 28, 2013 10:36 pm
Yep as said, keep on bashing it, it'll go in the end.
PostPosted: Wed Aug 28, 2013 10:58 pm
[quote="Roc"]Yep as said, keep on bashing it, it'll go in the end.[/quote]
:evil4:
Dale
PostPosted: Wed Aug 28, 2013 11:12 pm
how rude Mark :lol:
Roc
PostPosted: Thu Aug 29, 2013 10:52 am
[quote="Dale"]how rude Mark :lol:[/quote]
It's not me with the dirty mind :lol: :lol:
Rizzi1
PostPosted: Thu Aug 29, 2013 8:12 pm
Hi people and thanks for the replies, Still no success, cant afford to replace cv joints if they get damaged, both sides are well solid, already spent around £170.00 on parts for mot I cant justify spending anymore so it's time to get rid :( been a good car in the two years I've had it only issue a misfire caused by a faulty HT lead, time to ring the scrap man :cry: some of the replies made me chuckle :D
PostPosted: Thu Aug 29, 2013 11:24 pm
What's your location and spec of the car?
If the car is in fair nick and you're in the right area someone on here might take your car off your hands
paul323f
PostPosted: Sat Aug 31, 2013 12:34 pm
Put the nut on the end so you don't damage the end of the shaft, then get a mahoosive hammer and hit it really hard. But then you still may not be able to get the cv joint off to change the boot, so do what I did. Remove the whole driveshaft from the gearbox. In your case you will need to take the hub out as well. Once it's out you need to remove the knobly end that went into gearbox, this is pretty much just a circlip holding it on. Remove that then you can slide off both the inner and outer gaitors. Slip the new one on and refit it all. It's only awkward putting the clip back on the inner gaitor when you refit the shaft but it's a better option than scrapping the car
Rizzi1
PostPosted: Sun Sep 01, 2013 9:36 pm
Tried hitting shaft with Blunt end of a big axe made no difference, thought about removing all the drive shafts like suggested, on having a good look round car I found more faults, water leak, needs at least one brake calliper, rear bumper need reaffixing, so decided to scrap car in the end, a sad day but not got the patience to mess around anymore, maybe its an over forty thing :lol:
Rizzi1
PostPosted: Wed Sep 04, 2013 11:19 am
Tried the big hammer trick and I mean big, shaft didn't even move a mm, further inspection revealed other faults so sold the car as I could not justify chucking anymore money at it, shame really as the car was solid, only issue I ever had was a misfire caused by a knackered Ht lead. Don't know what car to get now I've gone of Mazda a little. Thanks for the help offered, Sean
Dale
PostPosted: Wed Sep 04, 2013 10:00 pm
I would have sorted it if you paid my petrol money to yours. Ive got a big sledge hammer. That would gave shiffted it. :D
Shame you sold it.
MattJones
PostPosted: Thu Sep 05, 2013 2:10 pm
If all you wanted to change was the boot then you should have just put the boot on the other side of the drive shaft.
Remove the drive shaft and hub together from the car completely, remove the circlip from the end and slide off the bearings (dont loose the clip) then remove inner boot, remove offending outer boot or cut it, slide on new outer boot onto the joint behind the hub then rebuild!
Sorry i know its a bit late :oops:
Thats what i had to do when my drive shaft and hub refused to seperate.
Roc
PostPosted: Thu Sep 05, 2013 2:41 pm
I'd have used a sticky boot in this situation. Done properly, these can last quite a while.
http://www.fordprobestore.co.uk/store/p ... cts_id=644
PostPosted: Wed Dec 11, 2013 12:10 am
[quote="Rizzi1"]Tried the big hammer trick and I mean big, shaft didn't even move a mm, further inspection revealed other faults so sold the car as I could not justify chucking anymore money at it, shame really as the car was solid, only issue I ever had was a misfire caused by a knackered Ht lead. Don't know what car to get now I've gone of Mazda a little. Thanks for the help offered, Sean[/quote]
Interesting, we had the same problem while doing lee and Nathan's GTR conversion to full disks, that was three years ago, we broke 6 pullers, it was given the Birmingham screwdriver treatment, attacked with the gas axe and subjected to a 30 ton press, never moved more than 3mm, I believe the guys still have it actually, ended up replacing the hub and shaft in the end!!!!!!!
PostPosted: Wed Dec 11, 2013 1:27 pm
[quote="andym323"][quote="Rizzi1"]Tried the big hammer trick and I mean big, shaft didn't even move a mm, further inspection revealed other faults so sold the car as I could not justify chucking anymore money at it, shame really as the car was solid, only issue I ever had was a misfire caused by a knackered Ht lead. Don't know what car to get now I've gone of Mazda a little. Thanks for the help offered, Sean[/quote]
Interesting, we had the same problem while doing lee and Nathan's GTR conversion to full disks, that was three years ago, we broke 6 pullers, it was given the Birmingham screwdriver treatment, attacked with the gas axe and subjected to a 30 ton press, never moved more than 3mm, I believe the guys still have it actually, ended up replacing the hub and shaft in the end!!!!!!![/quote]
Mr spel has it now :lol:
Dale
PostPosted: Thu Dec 12, 2013 5:10 am
After going back and reading this post I'm begining to wonder if he took the hub nut off :lol: :?
PostPosted: Thu Dec 12, 2013 11:35 pm
[quote="Dale"]After going back and reading this post I'm begining to wonder if he took the hub nut off :lol: :?[/quote]
:p
PostPosted: Thu Dec 12, 2013 11:36 pm
[quote="323F Rock"][quote="andym323"][quote="Rizzi1"]Tried the big hammer trick and I mean big, shaft didn't even move a mm, further inspection revealed other faults so sold the car as I could not justify chucking anymore money at it, shame really as the car was solid, only issue I ever had was a misfire caused by a knackered Ht lead. Don't know what car to get now I've gone of Mazda a little. Thanks for the help offered, Sean[/quote]
Mr spel has it now :lol:[/quote]
I forgot about that :) actually, he's just PM'd me some garage pics, wonder if its in any of them?
PostPosted: Fri Dec 13, 2013 12:17 am
[quote="andym323"]I forgot about that :) actually, he's just PM'd me some garage pics, wonder if its in any of them?[/quote]
Look behind his Sparco wheel ;)
