Club323F • View topic - Transmission problem
It is currently Tue Nov 10, 2026 1:34 pm
sitnalm
 Post subject: Transmission problem
PostPosted: Mon May 30, 2005 11:32 am
Hi all,
I have changed ATF recently (by machine) but my car still jerking. Normally this happen in the way like difficult to change from gear 1 to gear 2 and will jerk immediately after gear changed. Same thing to my reverse, the car will jerk if i pressure the pedal right after i change to "R" unless i give a second or two delay. My transmission is auto and clock 73000 KM. Advice needed urgently.
matt4u
PostPosted: Mon May 30, 2005 8:12 pm
Time for a tune up
DuFFMaN
PostPosted: Tue May 31, 2005 12:13 am
If it jerks, more likely the clutch??
Probably the pressure plates are failing? :?
matt4u
PostPosted: Tue May 31, 2005 12:27 am
its auto a???
DuFFMaN
PostPosted: Tue May 31, 2005 12:32 am
Must read threads properly :shock: :shock: lol :roll:
matt4u
PostPosted: Tue May 31, 2005 12:59 am
lol, we are all guilty of that, lol,
sitnalm
PostPosted: Tue May 31, 2005 1:40 am
Yes, it's Auto.
It's really not smooth.
any idea ?
sitnalm
PostPosted: Tue May 31, 2005 1:43 am
Can tuning detect if transmission got problem ?
matt4u
PostPosted: Tue May 31, 2005 2:11 am
Auto tran's need to be services roughly once a year
essex-lad
PostPosted: Thu Jun 02, 2005 5:14 pm
maybe a vacuum pipes come off or broken
matt4u
PostPosted: Thu Jun 02, 2005 11:45 pm
What happens is when you changed the oil the new oil is thinner so you need to tune the trans
sitnalm
PostPosted: Fri Jun 03, 2005 4:39 pm
I was wondering can we use Dexron III on our car ? as the manual said Dexron II
PostPosted: Sat Jun 04, 2005 11:49 pm
[quote="matt4u"]What happens is when you changed the oil the new oil is thinner so you need to tune the trans[/quote]
"Tune the trans".... please do go on :?
essex-lad
PostPosted: Sun Jun 05, 2005 12:27 pm
[quote="sitnalm"]I was wondering can we use Dexron III on our car ? as the manual said Dexron II[/quote]
You'll have to check with Mazda mate unless anybody else knows........ different oil for different tranmissions etc etc
sitnalm
PostPosted: Mon Jun 06, 2005 10:35 am
Thanks all
