Club323F • View topic - center dash speaker
It is currently Thu Nov 05, 2026 10:44 pm
da2el
 Post subject: center dash speaker
PostPosted: Wed Feb 11, 2009 3:43 pm
today I took this off
[img]http://img99.imageshack.us/img99/471/99873502tg2.jpg[/img]
it has 2 hards clips fixing it down
is there some kind of pre-instalation here to mount a center speaker or do I have to take all the dash to put the wires?
stuartspel
PostPosted: Wed Feb 11, 2009 3:53 pm
Quite a few folk have an extra speaker in her Rich/Deep2005, Hull BA I think too. Dont know if its plug and play though :dontknow:
richardesty
PostPosted: Thu Feb 12, 2009 8:09 am
No it's not plug and play........well not that I've found.
I originally had a tweeter mounted in there - but then used a kenwood speaker designed for a Fiat Punto - 70mm I think?
You have to extend the speaker cables to it, and adapt the grill slightly to make it fit.......................even then you can barely tell the difference.
PostPosted: Thu Feb 12, 2009 10:24 am
There is a block connector in there for speaker wiring but you'd have to find a speaker from a Type R or Type X to be able to plug it in. You could just plumb into this little loom to fit an aftermarket speaker :D
da2el
PostPosted: Thu Feb 12, 2009 11:57 am
since there is wiring shouldn't be hard to connect a speaker directly cable with cable :D
but richard you think it doesn't worth it?
da2el
PostPosted: Fri Feb 13, 2009 4:00 pm
searched and searched more and no sign of cables
the hole is little too
but well cleaned it very well
and will install under the cap a round air freshner ;)
Makz2008
PostPosted: Fri Feb 13, 2009 11:50 pm
that is a bloody good idea :)
da2el
PostPosted: Sat Feb 14, 2009 3:13 pm
Here is a guide of what I've done
1-
you will need a round air freshner and a rubber
[img]http://img14.imageshack.us/img14/6242/img002mh2.jpg[/img]
2-
open the air freshner so you can see the smelly disc
[img]http://img8.imageshack.us/img8/6537/img003do1.jpg[/img]
3-
put some "velcro" (that male and female stuff that gloes together) to avoyd plastic sounds in the future
[img]http://img17.imageshack.us/img17/734/img007sz4.jpg[/img]
4-
put all things together with the help of the rubber
[img]http://img10.imageshack.us/img10/9616/img004pf4.jpg[/img]
[img]http://img27.imageshack.us/img27/8707/img006co7.jpg[/img]
5-
this is what you get now put it on the car and enjoy :cyclopsani:
[img]http://img12.imageshack.us/img12/5634/img005ij7.jpg[/img]
Mase
PostPosted: Sat Feb 14, 2009 8:39 pm
Nifty idea. I like that. At least it makes use of a bit of redundant space. :thumbup:
[size=84][url=http://www.club323f.com/club323f/forum/viewtopic.php?t=14966]Record holder for the highest mileage from a 1.8i Exec BA - 428.9miles :razz:[/url] :D:D:D[/size]
wilko7
PostPosted: Fri Feb 20, 2009 7:30 pm
u can tell diffrence but depends what head unit u have, if u got a kenwood kvt 925 dvd screen then thay have 5.1 built in surround sound so u can tell the diffrence, i had a 3" speaker fitted.
wilko7
PostPosted: Fri Feb 20, 2009 7:31 pm
but likinthe idea of the smelly:P
da2el
 Post subject: Re: center dash speaker
PostPosted: Sun Dec 26, 2010 10:15 pm
found a speaker to conect in there but the cable has to come from far away
don't know if it worth the work
lewp91
PostPosted: Mon Dec 27, 2010 1:47 am
someone should get a multimetre n measure the resistance off the 2 pins in the plug when playing music :P
check its plugged in ;)
tarkoon
PostPosted: Wed Dec 29, 2010 11:50 am
That position will be perfect to fit center channel. You may use peerless 2.5-3 inches drive to fit on this position and need AudioControl System 90 Model 11 center channel amp/processor.
http://www.diymobileaudio.com/forum/cla ... essor.html
other than this is av processor.
MrKikker
PostPosted: Mon Jan 03, 2011 6:59 pm
put both tweeters from my composet in there, when the weather improves i'm going to mount them near the door mirrors. the center-spot just doesn't cut it..
