Club323F • View topic - Breaks
It is currently Mon Nov 09, 2026 7:42 pm
TriGa
 Post subject: Breaks
PostPosted: Sun Oct 17, 2004 11:12 pm
everytime i break my car makes this weird creekin noise similur to when u open a gate or a door that makes a creekin noise :? could it b my brake disks need changin?
Lantis
PostPosted: Sun Oct 17, 2004 11:29 pm
more importantly check the pads to see the wear and fade if thats not the case then it mite be the discs
Wai.Cheung
PostPosted: Sun Oct 17, 2004 11:34 pm
do you get this problem when braking from high speed or low? does the steering wheel judder slightly in your hands? Do you get the noise when going round sharp corners (whilst NOT braking)?
I had a similar problem; the car would SCREAM when I braked from slow speed and would judder the wheel like mad when slowing from high speed. The car stayed in a straight line but it scared the hell out of any passengers!! :shock: It would also make a noise when I went round tight corners (must have brought the pads back into contact with the disc through centrifugal force as the brakes were not being applied)
New discs sorted it.
If you are getting the noise without the judder then there is a good chance that your pads have worn down to the 'indicator'; it has been designed to make nasty noises when you're running short of friction material!
PostPosted: Mon Oct 18, 2004 9:36 am
I had a wierd knocking noise coming from the front left but new discs and pads sorted it
PostPosted: Mon Oct 18, 2004 11:30 am
wai - you would have had warped discs.... hence why new discs sorted it!
TriGa
PostPosted: Mon Oct 18, 2004 5:15 pm
well for some reason the noise stopped 2day :?
PostPosted: Mon Oct 18, 2004 5:58 pm
sometimes get rust down there - after a while it rubs clear and the noise dissappears -
all I can say is If it aint broken now dont bother fixing it :P
Still it might be worth checking all the same
TriGa
PostPosted: Mon Oct 18, 2004 10:29 pm
aint got n e cash to fix n e thin this month, so im glad it fixed itself lol
