Club323F • View topic - Automatic to manual KF-DE 323f
It is currently Thu Nov 05, 2026 7:06 am
evil-323f
PostPosted: Wed Sep 05, 2018 8:50 pm
Hello, i got manual gearbox,brake pedal and all of parts for conversion. Is there any problem if i dont change the ECU and run the manual gearbox with automatic engine ECU?
Someone did it before?
PostPosted: Wed Sep 05, 2018 9:26 pm
I seem to remember that auto ecu and manual box is ok but won't start in gear with just clutch pressed. I have manual ecu if you need one.
evil-323f
PostPosted: Sat Sep 08, 2018 7:10 am
That means i need to put N and than will start engine?
PostPosted: Sat Sep 08, 2018 2:32 pm
Yes, theres a neutral switch on gearbox Manual ecu just uses it while ticking over for fuel air mix i think, but auto wont allow start up in drive or reverse
PostPosted: Sat Sep 08, 2018 2:35 pm
I have used auto ecu in my already manual ba. One thing before you swap tho, you'll need the manual gearbox bolts. The auto ones are a good 40mm shorter
evil-323f
PostPosted: Sun Sep 09, 2018 5:31 am
Thanks so much! So i will order clutch today and start swap!
evil-323f
PostPosted: Sat Oct 06, 2018 7:04 pm
Swap ready bro, engine start was problem but i find a easy way to do it, just did bridge on automatic gearbox installation between 2 of the cables and everything goes perfect now
PostPosted: Sat Oct 06, 2018 8:32 pm
glad you sorted it, now just remember to use your left foot lol
