Club323F • View topic - I have lost my key
It is currently Wed Nov 04, 2026 1:12 pm
aandrr
 Post subject: I have lost my key
PostPosted: Thu Dec 04, 2014 8:20 pm
Saddly I dont have a spare key.
What should I do?
Please.I need help.
 Post subject: Re: I have lost my key
PostPosted: Thu Dec 04, 2014 9:23 pm
Oops :(
Well, if your doors are locked I guess first you'll have to break in, or ask your breakdown company (if you have a policy with one) to do it for you :?
After that, BAs usually have an engine immobiliser as standard. I've no idea if you can bypass it and hotwire the ignition, and if I did, it would be irresponsible to say how on a public forum - perhaps someone will be willing to email/PM you with that info, if they have it!
As for the key, I guess you'll have to go to Mazda for a new one and get it programmed for the immobiliser (but someone might correct me about that). They might ask for your chassis number.
Good luck!!
sneakz
PostPosted: Thu Dec 04, 2014 9:30 pm
Yes, you have to break in I think.
You can take the immobiliser out and just get a full lock set incl the ignitionswitch from a donor vehicle. Mine didn't have a standard immobiliser only a sketchy wired alarm which I took out soon after I purchased it.
If yours doesn't have one either you can just switch locks from a donor.
I think I have a full set incl 2 OEM keys but I'd have to check first.
Arne
PostPosted: Thu Dec 04, 2014 9:43 pm
[quote="sneakz"]Mine didn't have a standard immobiliser only a sketchy wired alarm[/quote]
True, some might not have them. Immobilisers became mandatory in UK in 1997 in any case, I'm not sure about anywhere else.
aandrr: if the ignition looks like [url=http://i5.photobucket.com/albums/y153/7thCrow/Mazda%206/Mazda6002.jpg][b]this[/b][/url], it has an immobiliser
aandrr
PostPosted: Thu Dec 04, 2014 9:44 pm
I was thinking to get a ignitionswitch +The key for it, but I have an immobiliser ..how can I take it out?
sneakz
PostPosted: Thu Dec 04, 2014 9:49 pm
Most of the time it is just a little box wired in between a cable, just solder them back together.
aandrr
PostPosted: Thu Dec 04, 2014 9:52 pm
But what will the ECU say ?
Squidy
PostPosted: Thu Dec 04, 2014 10:56 pm
Depending on the age of your car you might find any old Mazda key will work. I once locked myself out after fitting an alarm, didnt realise I left the keys in the ignition and the 'unlock' wire wasnt connect :roll: I had a box of old car keys and went through them, found one that fitted and jiggled it and viola! I guess the barrel inside has just worn down over years and isnt so picky
sneakz
PostPosted: Fri Dec 05, 2014 12:46 pm
De keys don't have a sensor or anything in them. Unless you have a remote you won't have any problems.
I've never been able to open up with another key tho. I think you'll need to change the locks.
aandrr
PostPosted: Sat Dec 06, 2014 9:49 pm
sometimes i see light in the dash with a key and the car, whats that for ?
PostPosted: Sat Dec 06, 2014 10:22 pm
[quote="aandrr"]sometimes i see light in the dash with a key and the car, whats that for ?[/quote]
That's the immobiliser ("security") light to show whether the car is seeing the key's chip.
