gooseboy78 wrote:
all goods.
jumping while braking?
do you mean pulsing through the pedal and having trouble stopping? thats a cracked or warped brake rotor and or disc.
loose feel through the steering is usually the the steering rack has become loose and needs tightening.
dampers or shock absorbers are replacable parts.
unusual movement in the gear stick may just be loose or broken linkages.
Hi! Thanks for your reply! I'll try to make myself as clear as possible.
About the brakes, yes, I think the correct term would be pulsing while braking, but just when nearly stopping. I don't remember if I feel it in the pedal or just in the car itself. I think the rear brake is drum brake.
The steering does not feel loose, I feel loose the front end of the car, like the suspension and steering components. I feel it while crossing the railway or some hard speed bumps. But the car steering itself is okay.
Well, probably I'm going to change the dampers before changing the tyres so I won't have problems with the tire settlement.
And finally, I've read the the loose feel on the gear stick is usually caused by worn out pieces connecting the gear stick with the linkages. I think these pieces are called bushings.
As I don't have spare money for the car, I haven't started yet. But probably the first thing I'm trying to fix by myself is the loose gear stick. But what about the engine? What should I check?
Again, thanks for your reply.
