Club323F • View topic - max turbo preassure
It is currently Thu Nov 05, 2026 4:43 pm
evil-323f
 Post subject: max turbo preassure
PostPosted: Wed Apr 16, 2014 3:34 am
Hello everyone!
What is max preassure for turbo for z5 engine?
sneakz
 Post subject: Re: max turbo preassure
PostPosted: Wed Apr 16, 2014 8:27 pm
We've all tried this and experimented with it..
There is none on this forum at this point in time with a working z5 turbo, some are working on it or have done it in the past. Most have tried and failed.
Now for a real answer, the z5 has not been designed as are turbo engine. Therefor it can only handle a little bit more I think a maximum of 130hp is probably possible for a few thousand miles if driven with care.
Also a word of advise.. do not post this random questions without any further info or even trying to explain anything about the project. I can assure you most people, incl myself, hate this.
PostPosted: Wed Apr 16, 2014 9:07 pm
I agree with Sneakz on this matter. It cost's way too much to get the Z5 in any shape to take any real boost from a turbo. You would be much better off buying a bigger or already turbo setup and dropping it in.
I found i spent a hell of a lot when i supercharged my Z5 for a while :(
nat1979
PostPosted: Wed Apr 16, 2014 11:22 pm
Lerch my good friend, I may need to pick your brain about that super charging business. So expect am from me sometime matey.
PostPosted: Sat May 03, 2014 12:50 pm
It should be able to hold a decent pressure between 0.5 en 0.7 bar (7 or 10psi). Most N/A engines can deal with it, however it depends completely on the whole engine package. If the engine is in proper condition and you will use a controllable fuel management system or full standalone, it will do fine.
[url=http://got.pc-mania.nl/mazda/speclist-en_turbo.txt]'95: 323F BA 2.5 V6 J-spec @ [color=darkred][i]290 pk/ 322 nm[/i][/url][/color]
