Club323F • View topic - I HAVE BIG PROBLEM :(
It is currently Thu Nov 05, 2026 4:21 pm
aandrr
 Post subject: I HAVE BIG PROBLEM :(
PostPosted: Wed Apr 04, 2012 5:18 pm
Hello to everybody .. I have a sad (for me at least) problem .... I had trouble with watter getting inside the car sa i removed the dashboard, found a lot of watter there , i figured out it was licking from the window, it`s been taken care of...
So while i`m putting the dash back piece to piece...all was good , radio working , light working...etc.
After i finished , i stoped the ignition then put it back on ; Surprise ! Radio dont work anymore; the beep sound whe u open dor and leave light open not working , the licht from the middle and the ones in front not working ( sunroof is warking ) ..small light from key is not working ; lights from dors not working ; the clock from the dashboard not working ; the button that says " lock dors" not working ( but i can still close the car with the remote i bought ) ; ....
still working are the : light from dashboard; headlights , sunroof, taillights , fog light , windows , heater, an the car it`self, i can drive it ;
I`m deperate , what is going on please if somebody can help me :(((
i checked the fuses , the only bad one was from radio , all rest are fine
MrKikker
PostPosted: Thu Apr 26, 2012 9:54 am
did you check EVERY fuse, including ones of which you think couldnt be it?
sounds like the "room" fuse has blown.
[img]https://lh3.googleusercontent.com/-24u5Bto2u3c/T2eBoxbIJKI/AAAAAAAAB08/wnxRTMmDejc/s800/IMG_0221.JPG[/img]
also check the tail, radio and cigar fuses.
you might as well check the fusebox under the bonnet, there are a few large ones there but also some small ones. might be worth checking out.
