Club323F • View topic - BP22 intake camshaft on 1.8l DOHC engine
It is currently Thu Nov 05, 2026 1:52 am
TheMAN
PostPosted: Sat Oct 13, 2007 7:42 pm
I was checking the parts catalogue and found out there's a different camshaft for the leaded fuel BP-ZE motor... anyone know any specs on this? It should be listed in the service manual if any of you guys have it. I'm going to have to assume that it has a more aggressive profile at the moment as that is typically the case for many Japanese engines in Europe. I know this for a fact with the FE3 motor and the Nissan CA16DE.
PostPosted: Sat Oct 13, 2007 7:49 pm
All our BP engines were un-leaded mate.
I think the BP22 cam was fitted in our 140bhp 1.8GT 323 before 1991.
maylander739
PostPosted: Sat Oct 13, 2007 7:56 pm
yep, it was on the pre cat version of the gt engine, do a search and you'll find a load of info on it
TheMAN
PostPosted: Sat Oct 13, 2007 8:38 pm
these are the 2 true relevant threads I've found in the NA performance BG section... http://www.club323f.com/club323f/forum/ ... hp?t=19583
http://www.club323f.com/club323f/forum/ ... hp?t=17715
very good info, except I'm looking for more specifics so that I can add that information into the FAQ
the "pre-cat" BP is the leaded fuel version... back in ye olden days, you guys had leaded petrol ;) use of leaded petrol in a catted car would mean it will clog it up and/or ruin it
anyone know of the valve timing specs of them? lift? if someone here has access to the UK/Europe service manual, it will be in there under the technical data sections... otherwise it will be in the training manual
PostPosted: Sat Oct 13, 2007 8:45 pm
The pre-cat BG was unleaded.
No UK 89 onwards Mazda ran on leaded fuel. Whether they had a cat or not. :wink:
I do believe someone here has the service manual, or the big yellow book as its also known.....
TheMAN
PostPosted: Sat Oct 13, 2007 8:59 pm
ok, symantecs... regardless, that engine and ECU was tuned to run on leaded fuel... the same engine was sold on the LHD versions on the continent during that time where those countries were still using leaded fuel ;)
DaVe0r
PostPosted: Sun Oct 14, 2007 9:37 am
really so the BP22 cams, Pistons (9.8:1) and ECU are for Leaded fuel only
interesting ...me thinks AV Gas for the current N/A build
It explains alot,, No 02 sensors, No Cat, different idle controll etc
In NZ we had one other car that came fitted with the 1.8 BP22 engine, that was the Ford laser TX3 ..not sure what year thou!! guessing 1989+
i dont no when Unleaded fuel was stopped in NZ
PostPosted: Sun Oct 14, 2007 10:44 pm
[quote="DaVe0r"]really so the BP22 cams, Pistons (9.8:1) and ECU are for Leaded fuel only
:roll: No.
They [i]might be[/i] suitable or tuned for leaded fuel in other countries, I don't know, but UK spec BG's were never ran on leaded fuel. According to the handbook that came with my BG GT, which was a pre-cat, it was to be run on unleaded only, as leaded fuel could cause damage to the engine.
I had no cat and no O2 sensor.
TheMAN
PostPosted: Mon Oct 15, 2007 6:04 am
the owner's manual is wrong, like many instances I've found in other years of the "323"
if the car has no cat, no O2 sensor, running the BP22 cams, high compression pistons, and uses the BP22 ECU, then [b]IT IS tuned to run on leaded fuel[/b]
it doesn't say so in the UK parts catalogue, but looking at the LHD european one does indicate that it is for leaded fuel
there's no reason not to run an EFI engine without an O2 sensor except for when using leaded petrol... the reason being is the lead will plug up the sensor and render it useless... the cat isn't there either because the lead will screw it up!
when running an engine designed for leaded petrol with unleaded, you should be using the highest octane available because lead in the fuel originally is meant to be an "easy" octane booster and also helps "cushions" engine internals
PostPosted: Mon Oct 15, 2007 5:13 pm
So it could have been run on leaded fuel without making any adjustments whatsoever?
Surely the ignition timing would need adjusting? :dontknow:
I used to run my BG on super unleaded, which is 97ron.
TheMAN
PostPosted: Mon Oct 15, 2007 6:32 pm
yes it will run just fine with no adjustments
TheMAN
PostPosted: Thu Oct 25, 2007 5:58 am
bump for more info
TheMAN
PostPosted: Sat Oct 22, 2011 9:59 am
necroing this thread again... I really want to know more about this engine!
Anyone manage to get the real Mazda shop manual or have access to one (bribe the dealer)? A mere photocopy of the technical data pages is sufficient!
Jacek176
PostPosted: Thu Mar 22, 2012 10:20 am
Hello,
here you is an article about differences about different versions of BP engines:
[url]http://www.clubprotege.com/forum/showthread.php?55020-SOHC-103hp-vs-DOHC-128hp-vs-DOHC-137hp-differences[/url]
Originally it was written by me, translated from polish to english by l3mur91. Camshafts research was done by jackkpl
lewp91
PostPosted: Thu Mar 22, 2012 3:49 pm
[img]http://www.alfabb.com/bb/forums/attachments/alfetta-gtv6-1975-1986/52136d1166059834-gtv6-motor-swap-w-non-alfa-motor-breaking_news_-_thread_resurrected-21_dead_thread_br.jpg[/img]
Jacek176
PostPosted: Thu Mar 22, 2012 6:44 pm
Don't you have anything more intelligent to write?
If you say that this thread is dead you might as well say that this whole forum is dead. At least this subforum. It was 4th or 5th topic from the top.
lewp91
PostPosted: Sat Mar 24, 2012 4:42 am
it was a joke :)
mazdaman323
PostPosted: Wed Jul 04, 2012 11:10 am
i had a bp22 engine in my 323 bg 3 door. it was a pre cat version so it had no lambda sensor and was meant for un-leaded fuel. i know this because it was plastered all over the car! lol. inside the fuel cap it said unleaded only and also in the owners manual. i still have the air flow meter, ecu and cams if anyones interested. hope this helps
mazdaman323
PostPosted: Fri Oct 24, 2014 8:25 am
as i now have another one of these engines i have done a lot of research involving speaking with Mazda directly. they have confirmed that going by the chassis number (BG137) the seven in the start defines fuel type which is LEADED fuel. Because of the robust design of the engine it can easily handle unleaded fuel. the lead in the fuel in other cars used to look after the valve guides and seats but due to Mazda being awesome they already used toughened guides and seats. i have also read that the exhintake cam swap does not work using BP05 and a BP22 Cam. you need to use two BP06 cams from a slightly later mx5 or 323. although the standard cams in the BP22 engine are better than BP06 x2 cam swap. there is a more even pull in torque over the rev range. i have a spare set of BP22 cams in stock if anyone is interested.
Thanks for reading
Si
HMT
PostPosted: Fri Oct 24, 2014 8:11 pm
So what's the exhaust cam in a BP22 engine?
mazdaman323
PostPosted: Wed Oct 29, 2014 1:39 pm
the exhaust cam is a BP05 and the intake is BP22.
mazdaman323
PostPosted: Thu Oct 30, 2014 9:03 am
just had my spare inlet cam measured. its 237 duration and 8.6mm lift
