Club323F • View topic - Draining the Radiator And Engine!
It is currently Thu Nov 12, 2026 10:31 pm
QBall
PostPosted: Tue Oct 04, 2005 3:33 pm
Is there any easier way to drain the water on my 180se Astina? What Anti-Freeze do you guys recommend?
BasterdB
PostPosted: Tue Oct 04, 2005 4:11 pm
Unclamp the pipe at the bottom off your radiator (Closes to the Block)
pk1
PostPosted: Thu Oct 06, 2005 11:21 pm
unboltin that hose though may just drain whats in the rad and the header - for total drain, run the engine for a few secs (from cold) until its all come out, then you can fill up with exact amount as specified in the manual (6 liters ish)
QBall
PostPosted: Tue Oct 18, 2005 6:17 am
There is a small plug at the bottom of the radiator. It sits behind the driver side's spotlight or plastic cover for the models without spots.
