Club323F • View topic - mazda 323f 1.5 lxi smoking
It is currently Thu Nov 05, 2026 4:38 am
gingerdowling
PostPosted: Tue Oct 12, 2010 9:27 am
can any one tell me or help me to figer out why it smokes like hell in the morning and then ok through the rest off the day is there a commen fault if so how can i fix it.
PostPosted: Tue Oct 12, 2010 9:28 am
Search the forum :roll: it's quite a common problem :thumbleft:
I just searched for "smoking start" - these were on the first page alone :lol:
http://www.club323f.com/club323f/forum/ ... king+start
PostPosted: Wed Oct 20, 2010 10:30 pm
What engine size have you got?
Mine does this, dodgy inlet valve on number three cylinder, been like it for a couple, maybe 4 years, doesn't seem to affect performance on my 1.5 :D
Gedas
PostPosted: Wed Oct 20, 2010 11:35 pm
Can't it be just condensation from the exhaust?
PostPosted: Wed Oct 20, 2010 11:37 pm
Only if its white :thumbleft:
Simondo
PostPosted: Thu Oct 21, 2010 7:40 am
[quote="Gedas"]Can't it be just condensation from the exhaust?[/quote]
There's a clear, clear difference between smoke and condensation. I have condensation on a cold start. Smoke is a lot more obvious. I'd be worried if people couldn't tell the difference between the two.
You're welcome.
Gedas
PostPosted: Thu Oct 21, 2010 10:59 am
Well I (and you aswell) haven't seen the smoke of his car, so... You might be right, I was only guessing. Notice the "?"?
Simondo
PostPosted: Thu Oct 21, 2010 11:37 am
I know. ;)
Didn't mean to offend or anything? :thumbright:
Was just saying that it should be easy to determine between smoke and condensation.
[img]http://i.ytimg.com/vi/8x8t2eZP_zs/2.jpg[/img]
You're welcome.
Gedas
PostPosted: Thu Oct 21, 2010 12:32 pm
No offense taken ;)
Paul Dethick
 Post subject: Re:
PostPosted: Thu Oct 28, 2010 1:33 pm
[quote="andym323"]What engine size have you got?
Mine does this, dodgy inlet valve on number three cylinder, been like it for a couple, maybe 4 years, doesn't seem to affect performance on my 1.5 :D[/quote]
Try ramming a sh*t load of carb cleaner through it. I put a 500ml can through mine and it now purrs. Somethimes they get gunked.
If only the body work was as good as the engines on these!
 Post subject: Re: Re:
PostPosted: Mon Nov 08, 2010 10:18 pm
[quote="Paul Dethick"][quote="andym323"]What engine size have you got?
If only the body work was as good as the engines on these![/quote]
Dude, Meanie gets Forte on a regular basis, are you saying put carb cleaner in the fuel? On my car she only smokes on start up, once warm shes fine :) ish :p
jaza58
PostPosted: Sun Aug 12, 2012 12:04 am
hi, I and my daughter both have 323f's 95 & 98 1.5's, & they both smoke on cold starts, oil smoke is blueish & smells of oil, water vapour on a cold morning start will smell sweetish of petrol.
blueish/grey smoke on start up usually is worn valve seals/valve guides when engine expands the gaps close & much less oil is drawn into intake & burnt you either live with it or spend a lot on a top end overhaul if it smokes all the time it could be piston rings blown head gasket or very worn valve seals/guides.
