Club323F • View topic - quick one
It is currently Fri Nov 06, 2026 11:50 am
margi
 Post subject: quick one
PostPosted: Sun Apr 26, 2009 11:00 am
i prob covering old ground for which im sorry but i was wondering if a turbo kit for a mazda 626 and mx6 will fit on my v6 323?
many thanks
ph3n1x
PostPosted: Tue Apr 28, 2009 9:56 am
Well, the manifold only fits the engine it is designed for. If the 626 has a somewhat different engine, it will not fit.
If it fits, then you need the space to mount the turbo. Where the 626 is bigger than the 323f, this could be a problem too.
Same thing for the intercooler. All the piping needs to be done right, yet again a size problem, so probably going to be a custom set of piping.
So to make i short, make sure that you use the same engine, exactly the same! Have a good look at the pictures where they fitted the turbo setup, and spot the differances between the 323f and the 626 in space. Try to have a workaround for it.
See how the did the intercooler, this is one hell of a job to get done right.
So there is a lot to look at.
Also have a look at the other turbo 323f, and read how they did their stuff and wich the problems were they ran into.
RHRH
PostPosted: Tue Apr 28, 2009 11:57 am
With the V6 its easier to do a supercharger, but it
wont fit properly under the bonnet.
margi
PostPosted: Thu May 21, 2009 9:21 pm
[quote="RHRH"]With the V6 its easier to do a supercharger, but it
wont fit properly under the bonnet.[/quote]
guessin i would need a hence hole in bonnet for it and only drive it in dry weather?
sounds a plan tho :D ill be looking in to this in greater detail in the coming weeks
just off topic a lil
can the old mark or new mark turbos fit the v6 ba?
