Club323F • View topic - cd player aerial
It is currently Sat Nov 07, 2026 1:46 pm
rodgtt
 Post subject: cd player aerial
PostPosted: Wed Mar 11, 2009 10:45 am
anyone know how i can disconnect the aerial? everytime i turn the igniton on and off im getting the aerial sound for 10 seconds. have no aerial tho so its just annoying!
is there a wire i can disconnect at the back of the headunit? or can i disconnect the aerial in the boot itself?
doing my nut in!
Roy le Waa
PostPosted: Wed Mar 11, 2009 10:59 am
I had exackly the same problem mate
Theres a plug in the side of the electric ariel in the boot, just get access by removing the plastic boot cover and unplug it
What I did was took the ariel out altogether (as the nylon cord was goosed) removed the cord and put it back together without the power supply and its just a manual ariel until I eventually get a working electric one
rodgtt
PostPosted: Wed Mar 11, 2009 2:45 pm
ahh sorted, thanks!
would it not be easier to just remove a wire from behind the dash??
otherwise ill be disconnecting the aerial later this evening
Roy le Waa
PostPosted: Wed Mar 11, 2009 4:09 pm
I thought it would be easier to just disconnect the power from the ariel itself as the boot covers only held on with 4 or 5 plastic plugs
I converted mine to manual in about 10 minutes, you will see the power supply straight away as soon as you remove the plastic boot cover
gez021
PostPosted: Wed Mar 11, 2009 7:24 pm
Good evening all . I am in the process of changing the electric antenna on my new 3232f . looked on ebay and came across 2 sizes of mounting hole 10mm or 22mm .
could anyone lead me in the right direction without me having to take it apart before i have a replacement part
thanks
paul323f
PostPosted: Wed Mar 11, 2009 10:30 pm
Turn af/ta announcements off and the aerial shouldn't move if your lucky! As for the size not got a clue, always get mine from mazda for £30
rodgtt
PostPosted: Thu Mar 12, 2009 11:53 am
cool ill try it out later. just out of curiosity how do u turn the af/ta off? got a kenwood player and i can the see the ta logo but cant for the life of me get rid of it! cheers for the help
DKZ
PostPosted: Thu Mar 12, 2009 12:54 pm
What model Kenwood?
Usually just flick through the menu, it'll be in there.
Mind you, I tried that on my old Kenwood, didn't to jack sqwat.
rodgtt
PostPosted: Thu Mar 12, 2009 2:01 pm
my mistake...its a JVC...dunno about the model but its pretty basic. only menu i can find is the bass, tremble, loud etc. no ta on there tho!
steven
PostPosted: Thu Mar 12, 2009 2:18 pm
My Car: 1998 Imola
i have a JVC and i think you switch the TA (traffic alerts) off by holding down the bottom right button for about 3 seconds, its either the AM/FM button or one similar, try holding buttons down until you see it switch off.
rodgtt
PostPosted: Thu Mar 12, 2009 2:45 pm
yeh thanks been trying all the buttons but still nothing happening. maybe its 2 buttons at same time?
Roy le Waa
PostPosted: Thu Mar 12, 2009 3:53 pm
If you google the make and model you can sometimes get the online manual for older/discontinued car stereos, I did that for an Alpine head unit that was discontinued in 2002, I downloaded and printed the owners book for it
worth a try maybe?
DKZ
PostPosted: Thu Mar 12, 2009 7:37 pm
Meh, easiest option so far is to rip apart the boot trim and unplug the aerial. Just do that dude, no more kafaffling around with menu's and all that.
rodgtt
PostPosted: Fri Mar 13, 2009 11:25 am
yeah will do later on. cheers
