Club323F • View topic - To all with smoking exhausts.
It is currently Mon Nov 02, 2026 11:43 pm
Post new topic Reply to topic  [ 72 posts ]  Go to page Previous  1, 2, 3  Next
A L 3 X
PostPosted: Thu Oct 30, 2008 1:19 am
[quote="Ringo"][quote="A L 3 X"]
the water didn't smell either[/quote]
At least now you know nothings pissin on your car aswell innit! :lol:[/quote]
lol.....think i found my problem though
Started it up today and had a real good whiff....smelt like fuel and added to the fact the plugs a bit sooted i think the car may be overfuelling slightly....any ideas how to go about sorting this?
PostPosted: Thu Oct 30, 2008 1:27 am
:roll: Jeez mate, I wish you'd hurry up and get a girlfriend!!!
A L 3 X
PostPosted: Thu Oct 30, 2008 1:32 am
jeez mate, i wish you'd help me out wi this....theres obviously sumthin wrong cos it aint condensation :?
Eire323f
PostPosted: Thu Oct 30, 2008 11:56 am
The exhaust is going to smell of fuel on start up because the choke will be on untill the engine gets up to temp. The condensation won't clear untill the whole exhaust system has heated up and even then there will be a certain amount of water vapour so unless its still smoking and smelling of fuel after the car has had a good long run and is nice and hot then don't worry about it. That's unless its plumes of black smoke coming out the exhaust.
Ringo
PostPosted: Thu Oct 30, 2008 2:57 pm
Alex, would I be right in saying your car doesn't get run all that often?
A L 3 X
PostPosted: Thu Oct 30, 2008 3:02 pm
its only getting run about once a day by my mum at the moment so thats probably why, my dad would take it like 3 times a day before....so its probably gonna carry on like this as i wont be able to afford the petrol to run it that much lol
so what about the sooted plugs then cos they're only like a few months old
Ringo
PostPosted: Thu Oct 30, 2008 3:15 pm
Don't know anything about the plugs personally, but as with the fuel smell on start-up, I'd agree with everything Eire323f said. especially if the car isn't gettin any decent runs, you'll be left with water/fuel vapours in the exhaust system, which you'd be able to smell on start-up. I remember trying to start up my old V6 after it had been sat for a couple of weeks and (when it actually started) it stank!
Get your mother to take it out for a proper drive to clear and shit out of it's system and see if that helps at all?
asifestoril
PostPosted: Thu Oct 30, 2008 4:30 pm
Very good thread this one.
Just one question is there a reason why newer cars don;t smoke as much or with some not at all?
This is on start up and after running for a while on a cold morning.
Just something that has bugged me for a while and always forget to ask.
Eire323f
PostPosted: Fri Oct 31, 2008 6:45 pm
On the sooted plugs it could be just the short trips on choke all the time, doesn't mean it's overfueling or they could be the wrong temp plugs.
Have a read
http://www.club323f.com/ba/guides/plugs/plugs.php
Cozz
PostPosted: Sun Mar 01, 2009 1:11 pm
[quote="scott5050"][quote="Anothersucker4a323f"][quote="ziggy323f"]valve stem oil seals - where are these located???[/quote]
on the valve stems :lol:
Cylinder head off job if I'm correct, if not I will soon be put in place no doubt :tongue:[/quote]
You're not correct. Go to your place!
You can use compressed air or nylon rope down the spark plug hole to hold the valve up while you change the stem seals.
Much easier doing it with the head off but not as much hassle as removing the head.[/quote]
So is this job possible for someone with not much experiance?
What tools/ parts do I need? Im guessing the car needs jacking up to do this?
shiftyraul
PostPosted: Sat Mar 06, 2010 3:04 am
I've got a question if you don't mind. My car's burns oil on start up, as blue smoke comes out. However, when the engine gets warm, it stops. If I start it again, with a warm engine, no smoke. The only theory I have is that one of my piston rings is leaking oil onto the cylinder, so when it gets warm it expands, sealing it and stopping the oil leaking onto the cylinder. Good theory or bad?
Cheers guys,
Raul
Debz
PostPosted: Sat Mar 06, 2010 9:07 am
Having exact same problem mate :(
If you read my post in the Ba section in the service section titled Got a Problem you'll see the similarity.
PostPosted: Sat Mar 06, 2010 12:34 pm
I'm still sticking to my guns Debz, and I think its the same story for shiftyraul here - worn valve seals.
I've never done this but a friend of mine suggested putting something like Engine Stop Leak in the oil? The name suggests it should help but I've never used the stuff :lol:
PostPosted: Sat Mar 06, 2010 2:32 pm
[quote="shiftyraul"]I've got a question if you don't mind. My car's burns oil on start up, as blue smoke comes out. However, when the engine gets warm, it stops. If I start it again, with a warm engine, no smoke. The only theory I have is that one of my piston rings is leaking oil onto the cylinder, so when it gets warm it expands, sealing it and stopping the oil leaking onto the cylinder. Good theory or bad?
Cheers guys,
Raul[/quote]
Sounds like a worn valve stem oil seal, it seeps down the valve stem into the bores/inlet ports when the engine cools down and then burns when you start it up from cool. It burns off, then stops smoking. It'll get worse eventually, but it could take a while to become a real worry. :wink:
RISINGT4
PostPosted: Fri Jul 29, 2011 9:15 pm
Hi guys this looks like my first port of call my car smokes on start up (oil) and then after about a minute its gone ive rebuilt the head full strip rebuild,skim seals etc but its still doing it any ideas dont really know much about the model but its a 323 LXI 1.5 with cambelt/chain??
PostPosted: Mon Aug 01, 2011 9:13 pm
It should be noted that the valve stem oil seals are different for the inlet and exhaust valves, even though they look the same. Could it be possible you've fitted them, or even just a few of them the wrong way?
silver-machine
PostPosted: Mon Aug 01, 2011 10:23 pm
Valve stem seals deffo. My wifes old 626 did it every morning. When you start it up, it just burns off the drop of oil that has dripped down.
silver-machine
PostPosted: Thu Aug 04, 2011 12:48 pm
Well my new car is deffo smoking. Just went for the mot and all the techies had to leave the garage for the emissions test :D
Apart from that it only failed 0n a bulb and 1 tyre.
So easy peasy then. Swap a tyre, change a bulb then swap the engine. Mornings work. I've done 200 miles since I got it and the dipstick is down to half already. I think the oil on a few plugs and on the plug leads is a bit of a giveaway.
RISINGT4
PostPosted: Fri Aug 05, 2011 8:57 pm
I spotted the different sizes ive just had a look at the pcv and it ratles and i also remember there was a lot of oil in the inlet side when i striped it down??
Simondo
PostPosted: Mon Aug 22, 2011 10:59 am
[quote="silver-machine"]Well my new car is deffo smoking. Just went for the mot and all the techies had to leave the garage for the emissions test :D
So easy peasy then. Swap a tyre, change a bulb then swap the engine. Mornings work. I've done 200 miles since I got it and the dipstick is down to half already. I think the oil on a few plugs and on the plug leads is a bit of a giveaway.[/quote]
You're laughing then! I have to put in a few litre of oil every week when I had this problem!
You're welcome.
steven
PostPosted: Sat Sep 17, 2011 12:35 am
My Car: 1998 Imola
Sooted spark plugs, especially within a few months of changing are normally due to an incorrect mixture of fuel/air, one of them being too rich. Have you got an obscenely huge induction kit or aftermarket fuel pressure regulator turned up too high ie a fse boost valve turned up way too high?
I agree with the majority here though it does sound like the all to common stem seals.
Murdo
PostPosted: Sun Jan 15, 2012 3:07 pm
[quote="steven"]Sooted spark plugs, especially within a few months of changing are normally due to an incorrect mixture of fuel/air, one of them being too rich. Have you got an obscenely huge induction kit or aftermarket fuel pressure regulator turned up too high ie a fse boost valve turned up way too high?
I agree with the majority here though it does sound like the all to common stem seals.[/quote]
Cheers Steven.. Saved me a question! Originally here because of white smoke (cheers op for the heads up) but your answer about the sooted sparks makes sense for me, as my intake hose was split in half for months.. meaning incorrect mixture of air/fuel.. So black plugs? Cause I've took the front three out and they were VERY black.. Can't get to the back three tho
Murdo
PostPosted: Sun Jan 22, 2012 10:32 pm
How about white smoke, that smells of fuel.. After 20-30 min run and warm engine/exhaust?
PostPosted: Sun Jan 22, 2012 10:55 pm
If you can smell fuel, then I'd say you're running a little rich, you really need to change all the plugs though, I'm sure there should be a guide for removing the inntake manifold to allow access to the rear bank :)
Murdo
PostPosted: Sun Jan 22, 2012 11:19 pm
Cheers.. I considere plugs due to front ones being über black!! I'll try and get rear bank done too
Simondo
PostPosted: Mon Jan 23, 2012 12:40 am
You don't need to remove the manifold to change the rear ones. as long as you've got a long tool. :evil4:
You're welcome.
Murdo
PostPosted: Mon Jan 23, 2012 9:31 am
That's the problem.. I don't. Well it's long enough but the handle at top stops it from turning :(
PostPosted: Mon Jan 23, 2012 10:38 am
Just get a longer spark plug tool - a billion times easier than removing the intake manifold for the first time :lol:
Simondo
PostPosted: Mon Jan 23, 2012 11:00 am
Agree with Hughie.
I removed an intake manifold the other day and it was a pain in the a**e.. and even that was with the knowledge that I wouldn't have to worry about re-fitting it again.
You're welcome.
Murdo
PostPosted: Mon Jan 23, 2012 11:22 am
I wouldn't go near the intake manifold.. I know when to leave the job for the professionals! I'm on the hunt for a longer spark plug tool!
