Club323F • View topic - 1.8 FSE boost valve fitting - keep
It is currently Thu Nov 05, 2026 5:54 am
M1tch
PostPosted: Tue Sep 11, 2007 2:26 pm
As I had my boost valve fitted yesterday (thanks Andy!) I thought I best take some photos :)
Take off the wipers and plastic trim from under the front windscreen so that you are able to fit the bracket provided
[img]http://i93.photobucket.com/albums/l49/m1tch_2006/DSC00232.jpg[/img]
Bend the bracket to fit where you want it
[img]http://i93.photobucket.com/albums/l49/m1tch_2006/DSC00234.jpg[/img]
Test fit the FSE so that you know it will fit where you want it
[img]http://i93.photobucket.com/albums/l49/m1tch_2006/DSC00233.jpg[/img]
Using the bracket create marks of where you want the holes in the engine bay
[img]http://i93.photobucket.com/albums/l49/m1tch_2006/DSC00236.jpg[/img]
File the holes down to get a clean fit
[img]http://i93.photobucket.com/albums/l49/m1tch_2006/DSC00235.jpg[/img]
Put the FSE together
[img]http://i93.photobucket.com/albums/l49/m1tch_2006/DSC00241.jpg[/img]
Test fit to check routing of pipes
[img]http://i93.photobucket.com/albums/l49/m1tch_2006/DSC00238.jpg[/img]
Carefully remove the Vacuum line using a craft knife to split the pipe to remove it
[img]http://i93.photobucket.com/albums/l49/m1tch_2006/DSC00239.jpg[/img]
This is where the vacuum line plugs into
[img]http://i93.photobucket.com/albums/l49/m1tch_2006/DSC00240.jpg[/img]
Use rags to place under the regulator so that fuel is soaked up and remove the original regulator
[img]http://i93.photobucket.com/albums/l49/m1tch_2006/DSC00242.jpg[/img]
[img]http://i93.photobucket.com/albums/l49/m1tch_2006/DSC00243.jpg[/img]
Add the billet adaptor, make sure its tight, but not too tight to strip the threads!
[img]http://i93.photobucket.com/albums/l49/m1tch_2006/DSC00244.jpg[/img]
Connect up the pipework to the FSE and ensure that all clips are tight
[img]http://i93.photobucket.com/albums/l49/m1tch_2006/DSC00247.jpg[/img]
What you should have left over
[img]http://i93.photobucket.com/albums/l49/m1tch_2006/DSC00248.jpg[/img]
PostPosted: Tue Sep 11, 2007 2:35 pm
Nice guide there Mitch :thumbleft:
M1tch
PostPosted: Tue Sep 11, 2007 2:38 pm
Why thank you lol 17 photos and 30 minutes later lol hmm oh I forgot that you might need to cut away some of the under bonnet padding to get the thing to fit without being knocked, I need to adjust it as the vacuum line is being bent over from the bonnet, but made a nice difference on the way back from andys :)
PostPosted: Tue Sep 11, 2007 2:39 pm
Got a plan for that now mate ;)
Murray
PostPosted: Tue Sep 11, 2007 3:44 pm
[quote="andym323"]Got a plan for that now mate ;)[/quote]
bonnet spacers? :lol:
M1tch
PostPosted: Tue Sep 11, 2007 3:55 pm
I dunno why FSE has decided to put the vacuum line on the top lol I mean I know theres a diaphragm in there that needs pressure change at the top, but I mean, could they not put the connector at the side? lol its bad enough getting it low enough to get the adjustment screw and cap under there lol now I have pipework extending from the top!!
PostPosted: Tue Sep 11, 2007 6:35 pm
It fits facing down and horizontal too - perhaps thats a fitting issue you need to take up with your mechanic :evil4:
PostPosted: Tue Sep 11, 2007 8:02 pm
[quote="stuartspel"]It fits facing down and horizontal too - perhaps thats a fitting issue you need to take up with your mechanic :evil4:[/quote]
Oi, can it Butterball :P
M1tch
PostPosted: Tue Sep 11, 2007 10:21 pm
Yeah you can fit it easier to one side or upside down, but then again you would have issues with adjusting it and fitting the setup guage on it! :D
PostPosted: Tue Sep 11, 2007 10:43 pm
I can't believe you've fitted it back to front!
M1tch
PostPosted: Tue Sep 11, 2007 10:48 pm
Huh?
PostPosted: Tue Sep 11, 2007 11:06 pm
He's pulling your leg :P
M1tch
PostPosted: Tue Sep 11, 2007 11:17 pm
Arg lol stop confusing the blonde lol this is the most expensive mod so far on my car lol
Putonyourshoes
PostPosted: Sun Sep 30, 2007 10:10 am
what sort of difference did it make chap?
high revs low revs
big improvement slight improvement
economy
value for money?:)
thanks looking into it for my car
M1tch
PostPosted: Sun Sep 30, 2007 10:11 pm
I need to wait for some 1/4 mile times really, I get less of that turbo lag effect when the VICS system opens lol but its not too bad, still deciding if its its worth it all I can say is that it smooths out the acceleration, I need to get a fuel pressure guage to set up properly really
DaveMc
PostPosted: Sat Apr 19, 2008 3:04 pm
Post bump
Nice guide its what i followed when fitting mine havent had the chance to try it out yet as ive no petrol and skint need to save for some V-power at crail :D
Have you noticed much a differnce since fitting?
Morpheus
PostPosted: Mon May 19, 2008 12:11 pm
[quote="M1tch"]
Any idea where I would get one of these (fuel rail adaptor)? got a FSE off ebay and it didn't come with one lol!
dannylangrick
PostPosted: Wed Aug 31, 2016 11:45 pm
Unfortunately I can't see the pics on this guide.... I've fitted an FSE boost valve on my V6 ZXI but I am unsure where the vacuum pipe attaches to the car from the FSE boost valve..... can anyone help me please??
Any advice would be much appreciated
Thanks in advance
