Club323F • View topic - Oil drinker
It is currently Sun Nov 08, 2026 9:40 pm
JohnLi
 Post subject: Oil drinker
PostPosted: Tue Nov 16, 2004 8:26 pm
Hello,
I've noticed I need to top up the oil on my 1.8 exec fairly often (at least 1.6 litres in 6 months) There are no visible leaks and no blue smoke, is this normal?
Ian.
PostPosted: Tue Nov 16, 2004 9:32 pm
possibly worn valve stem seals
PostPosted: Tue Nov 16, 2004 10:54 pm
haha...your cars drunk!! :?
My bros car had a phase it went through (daewoo)...At 55k-60k it soaked up oil like a sponge...We sold it at 61k at an auction as we kinda predicted the engines soon to fall apart...:roll:
But remember it was a daewoo...
 Post subject: Re: Oil drinker
PostPosted: Wed Nov 17, 2004 9:01 am
[quote="JohnLi"]Hello,
Ian.[/quote]
Mine was drinking oil - it was leaking from the distributor gasket and onto the top pipe (Takes water from the head to the radiator, so quite important :wink: )which eventually perished, bulged and sprung a leak. Not obvious, so I thought I'd mention. It's also occured on other 323s.
DAN 1.8
PostPosted: Wed Nov 24, 2004 8:48 pm
my 1.8 exec does the same has done it for 7-8 months now its the same prob as mark said on mine i will get round to doin it soon but until then ill just keep cheking the oil!!!!
dan 1.8
JohnLi
PostPosted: Tue Nov 30, 2004 8:30 pm
Thanks All,
I'll check it out and let you know how I get on.
Ian.
PostPosted: Wed Dec 01, 2004 4:02 pm
When I had my cambelt done last year, the garage said the camshaft oil seals were gone, and replaced them, and that reduced my oil consumption quite a bit !
foye
PostPosted: Mon Jan 03, 2005 8:04 pm
How hard is it to change the distributor gasget? i'm losing oil from there also
thanx
foye
PostPosted: Mon Jan 03, 2005 8:05 pm
oops i meant "gasket"
JohnLi
PostPosted: Tue Jan 11, 2005 7:52 pm
Nope, no sign of a leak. I got it serviced and MOT's today as well and it sailed through so I guess I just need to keep topping it up.
Ian.
foye
PostPosted: Tue Apr 12, 2005 4:17 pm
Soooo is it easy to change the distributor oil gasket? and is it called a distributor oil gasket?
PostPosted: Tue Apr 12, 2005 6:57 pm
Distributor oil gasket ('O'ring) replacement:
http://www.club323f.com/club323f/forum/ ... hp4?t=2432
I've got some pics as well that I'll post there.
foye
PostPosted: Tue Apr 12, 2005 9:01 pm
Thanks mark much appreciated
