Club323F • View topic - How to fit a 'touring car' sunvisor to your F....
It is currently Mon Nov 02, 2026 7:17 pm
PostPosted: Sun Mar 04, 2007 12:18 am
Each MOT I have to remove my sunvisor, as it's too deep to pass the test.
This time when replacing it - AndyM and Jam were around, so we decided to do a little guide..................
1. Thoroughly clean your windscreen using Meguiars quality glass cleaner, then decide on the desired depth for your visor:
[img]http://i72.photobucket.com/albums/i188/Richardestys/1-5.jpg[/img]
2. Open your sunroof (if pos), remove your shoes, and get a Jon Bon-Jovi look alike (this stage can vary the outcome) to pass you the roll of self adhesive vinyl film:
[img]http://i72.photobucket.com/albums/i188/Richardestys/2-5.jpg[/img]
3. Lay your film onto the screen, hold in place with masking tape then get a pair of closed scissors:
[img]http://i72.photobucket.com/albums/i188/Richardestys/3-5.jpg[/img]
4. Using the closed scissors, make a crease along the top curved edge of the screen, then cut this crease with a stanley knife. Then use your thumb to crease the film along the vertical edges of the screen:
[img]http://i72.photobucket.com/albums/i188/Richardestys/4-4.jpg[/img]
5. Lift the film (now with a shaped top edged) into the house and find a large flat area. Lay the film face down and use a marker pen to mark the verticle creases - whilst your Jon Bon-Jovi look-a-like drinks tea. Then, using your desired depth, make some marks measuring down from the top curve. Maisey used to have a 300mm depth visor, but traffic lights were a bit of a problem so we went for 280mm this time:
[img]http://i72.photobucket.com/albums/i188/Richardestys/5-5.jpg[/img]
6. Join the dots (if you number them with numbers in stage 5, this bit is easier :thumbleft: ), then cut out your marked shape using scissors:
[img]http://i72.photobucket.com/albums/i188/Richardestys/6-3.jpg[/img]
7. Here's how it sould now look (shaped to give you that 'flat bottom' look). Line it up on the car, then go get some Febreze......... Empty the febreze and put some water in it. Needless to say, any spray bottle will do:
[img]http://i72.photobucket.com/albums/i188/Richardestys/7-1.jpg[/img]
8. Get your spray bottle with your water, then get your safety gear on - you really don't know how serious this stuff could be:
[img]http://i72.photobucket.com/albums/i188/Richardestys/rad.jpg[/img]
9. You might choose to make it safe by adding a little fairy to the mixture - it helps you position the film. Then liberally spray your windscreen and the back of the film whilst removing the backing:
[img]http://i72.photobucket.com/albums/i188/Richardestys/8-1.jpg[/img]
10. Lay the film onto the car, then spray the outside of the film with your water/fairy mixture before squeegeeing the airbubbles out to the edges:
[img]http://i72.photobucket.com/albums/i188/Richardestys/9.jpg[/img]
11. Concentrate on getting all the air bubbles out around the edges, then use some kitchen roll to dry the film (water will come out of the edges when you remove the air) then admire your new sunvisor:
[img]http://i72.photobucket.com/albums/i188/Richardestys/10.jpg[/img]
Now - if you've just done your sunvisor and your Jon Bon Jovi Lookalike friend has a Sparkle Green F with a sunroof thats not so easy to stand through - here's an alternative method:
1. Remove existing sunvisor before cleaning the glass with whatever you can find. Here we used some tar remover to get rid of all the sticky gunk left by the previous vinyl:
[img]http://i72.photobucket.com/albums/i188/Richardestys/A1.jpg[/img]
2. Continue cleaning using any old tat (At this stage your Jon Bon-Jovi look-a-like may be a little tired from all the standing around) - before utilising your previous backing paper as a template. At this stage your Jon Bon-Jovi look-a-like friend may not have balls quite so big as yours, so you may need to reduce the depth for him. Here - we show a 210mm depth template:
[img]http://i72.photobucket.com/albums/i188/Richardestys/A2.jpg[/img]
3. Use the template to mark your vinyl, before placing on the car. Then spray the window and film backing as before:
[img]http://i72.photobucket.com/albums/i188/Richardestys/A3.jpg[/img]
4. At this point, it can be quite humourous to spray your Jon Bon-Jovi look-a-like friend with the said solution. Once he has dried off, you can sqeegee all the air and water out from the film. Then - you could attempt a single wiper conversion by simply eating one of your wipers :evil4: :
[img]http://i72.photobucket.com/albums/i188/Richardestys/A4.jpg[/img]
5. Once you've finished the wiper conversion you can compair the different depth sunvisors and cars:
[img]http://i72.photobucket.com/albums/i188/Richardestys/A5.jpg[/img]
:thumbleft:
stevo_b
PostPosted: Sun Mar 04, 2007 12:41 am
very usefull lads, and quite funny
how did u get bon jovi to come help u out tho? :lol:
da2el
PostPosted: Sun Mar 04, 2007 2:06 am
it was funny
and well done
maylander739
PostPosted: Sun Mar 04, 2007 11:27 am
very good guide, throughly enjoyed it, and it will come in handy when i persuade Mr H to do mine :lol:
PostPosted: Sun Mar 04, 2007 11:56 am
[quote="maylander739"]very good guide, throughly enjoyed it, and it will come in handy when i persuade Mr H to do mine :lol:[/quote]
Matt - I have one word to say to you................"Martini"
parvez
PostPosted: Sun Mar 04, 2007 12:11 pm
Nice one lads - good to see you had fun :D
PostPosted: Sun Mar 04, 2007 1:22 pm
great guide guys!
:O rich is that auto glym your using on andys car!?!?
lol
JAM
PostPosted: Sun Mar 04, 2007 1:25 pm
Wahey.... Someon noticed :D I was wondering how long it'd take before it got mentioned :laughing6:
parvez
PostPosted: Sun Mar 04, 2007 1:32 pm
I did notice it but thought it would best not to swear on the forum :laughing6:
By the way, what do you do if you dont have a Bon Jovi look-alike to hand?!?!? :lol:
EDWUMASTER
PostPosted: Sun Mar 04, 2007 2:15 pm
Nice one lads!!!
http://s42.photobucket.com/albums/e313/edwumaster/
http://www.youtube.com/profile?user=edwumaster
IOW323F
PostPosted: Sun Mar 04, 2007 5:51 pm
[quote="parvez"]
By the way, what do you do if you dont have a Bon Jovi look-alike to hand?!?!? :lol:[/quote]
Im sure anyone with a mullet will do :evil4: ;)
Funny guide tho boys :)
stevo_b
PostPosted: Sun Mar 04, 2007 7:59 pm
i think this guide should go in the guides section on the main site :thumbleft:
Dragon Rob
PostPosted: Mon Mar 05, 2007 2:23 am
Good stuff, but personally I'd do it with tinting film on the inside, that way you have no need to remove it each year and can still see the traffic lights. ;)
Full Circle:-
PostPosted: Mon Mar 05, 2007 9:18 am
[quote="323f rock"]great guide guys!
lol
;)[/quote]
Well spotted mate - please check out line one of doing andy's sunvisor:
"Remove existing sunvisor before cleaning the glass with whatever you can find" :evil4:
PostPosted: Mon Mar 05, 2007 9:19 am
[quote="Dragon Rob"]Good stuff, but personally I'd do it with tinting film on the inside, that way you have no need to remove it each year and can still see the traffic lights. ;)[/quote]
Hmmmmm. I'm told that anything other than a tax dic affixed to the inside top edge of the windscreen is an instant failure in the mot.
Dragon Rob
PostPosted: Mon Mar 05, 2007 9:52 am
Moby's passed plenty of times, in different test centres, like that. :D
Full Circle:-
PostPosted: Mon Mar 05, 2007 11:55 am
LMAO, I love this guide :D:D:D:D
Just back from returning the Bon Jovi costume to Mr. Ben's costume shop (younger viewers may need to ask you parents who Mr. Ben is ;) )
If I can just add one piece of advice, doing this job, its best to remember things are best kept slippery when wet :thumbleft:
As for the MOT issue, this is only the third time my visor has been changed in over 5 years, and its never failed an MOT :D:D
Depends on the tester I guess :scratch:
Big thanks to Rich for the new visor, gone for the Maisey look this time, my previous ones have been 'straight cut' ;) Lovethe new look, inside and out :thumbright:
JAM
PostPosted: Mon Mar 05, 2007 12:17 pm
Yup, Wetter is better ;)
PostPosted: Mon Mar 05, 2007 2:22 pm
:cry: .........................This time last year, just before the Scarborough meet - Rich arrived at my gaff nice and early to fit my sun strip too. I took eager mental notes of the procedure - knowing they would come in handy when I had to replace it this year.
MOT passed on Saturday and sunstrip cut ready - Applied it but it looked really dull, so took it off and did another with shiny stuff - problem was the shiney stuff was cheap stuff and within 48 hours appeared bobbley....... Off I went this morning to a sign makers for proper vinyl :D plus it was so wide I could make 2 out of it, just as well as it was real windy and the first one blew out of my hand - landing sticky side down on the grass, F'ing brilliant I thought.......... :cussing:
So, 4th one now on since saturday - getting to be a dab hand now though :laughing6:
PostPosted: Mon Mar 05, 2007 2:34 pm
Oh dear chap, damn that wind :?
You can borrow the Bon Jovi helper next time :lol:
edy_ea
PostPosted: Mon Mar 05, 2007 2:59 pm
Great guide guys ! looks like you have a laugh too.
Hmm so is Martini the "bribe" currenty Rich?? lol :occasion5:
Anyone want to cut and post one for the unsteady-handed?? haha !! :thumbup:
stevo_b
PostPosted: Mon Mar 05, 2007 4:21 pm
[quote="stuartspel"]:just as well as it was real windy and the first one blew out of my hand - landing sticky side down on the grass, F'ing brilliant I thought.......... :cussing: [/quote]
LMAO! :lol:
PostPosted: Mon Mar 05, 2007 6:05 pm
Some funny pics there boys, good work!!!
JAM
PostPosted: Mon Mar 05, 2007 6:11 pm
Thanks :D
PostPosted: Mon Mar 05, 2007 7:30 pm
[quote="edy_ea"]Hmm so is Martini the "bribe" currenty Rich?? lol :occasion5:
Martini refers to a very old advert.....
"Anytime, anyplace, anywhere!"
toon army
PostPosted: Thu Mar 15, 2007 5:37 pm
Location: PETERBOROUGH/CAMBRIDGSHIRE FORMELY NEWCASTLE/WALLSEND
Do you need a Jon Bon-Jovi look alike, as I only have a Meat Loaf one, and he,s not much good :pale:
BEAST FROM THE NORTH EAST
 Post subject: sun visor
PostPosted: Fri Mar 30, 2007 10:13 pm
I had same problem with mine i got pulled off police and they told me to take my sun strip off (how petty) so i done as they asked then went out and bought smaller wiper blades and a new strip and now they cannot say anything. what they going to do measure my blades.
PostPosted: Sat Mar 31, 2007 9:13 am
Nice one 'beast' - I like your style :thumbleft:
PostPosted: Sun May 06, 2007 2:13 pm
great guide fitted ours yesterday we used the first method as we can stand through our sunroof!! :D
LINK : [url]http://www.club323f.com/club323f/forum/viewtopic.php?t=17521[/url]
:cheers:
xlogic
PostPosted: Tue Jun 26, 2007 4:05 pm
Mine got through its MOT with the visor :P
