Club323F • View topic - Dimming Lights
It is currently Fri Nov 06, 2026 9:27 am
 Post subject: Dimming Lights
PostPosted: Fri Dec 13, 2002 10:34 am
I have a '94 1.8 GLXi. 400W amp driving a bass box. This seems to make the headlights dim slightly with the bass line. I've not checked the size of the alternator yet, but does anyone know for sure whether this will effect the charging of the battery dramatically?
If this is not good - can you get an uprated alternator - I guess the ZXi one won't fit.
Mark (tannerma2002)
halfcore667
 Post subject: dimming lights
PostPosted: Fri Dec 13, 2002 8:14 pm
Usually an uprated battery will sort it, try an optima yellow top battery or failing that a power cap should sort it, you'll only have to get an uprated alternator if you've got some serious ice
maz323f
PostPosted: Sat Dec 14, 2002 3:29 pm
The other option is to buy a power cap, you can get these from any car audio store. They are basically a battery reserve that and help prevent lights dimming, they also look very trick if you have a proper boot install
HTH
CraigC
PostPosted: Wed Dec 18, 2002 9:02 am
OK, Guys cheers. I've a nasty feeling the battery may be on it's way out anyway.
 Post subject: Diesel battery
PostPosted: Tue Apr 22, 2003 3:01 pm
Hi, i know its a bit after the fact perhaps, but i fitted a deisel spec battery from a peugeot i think, i have a pioneer 100w powered sub and it seems to have taken care of the problem unless i really crank it, cost about £35.
