Club323F • View topic - ENGINE - Shortshifter - keep
It is currently Mon Nov 02, 2026 10:45 pm
Post new topic Reply to topic  [ 88 posts ]  Go to page 1, 2, 3  Next
jhoeven
PostPosted: Mon Jan 31, 2005 9:19 pm
Here's my manual for installing a shortshifter.
Just rightclick the link and select "save as"
[url]http://www.home.versatel.nl/jhoeven/jeroen/Handleiding/Short-throw-shifter.pdf[/url]
Have fun
Greetz
PostPosted: Tue Feb 01, 2005 12:57 am
Are they good? where can you get them e-bay? Recon ill have me one of those.
Ben
PostPosted: Tue Feb 01, 2005 9:10 am
Excellent guide - very clear !
Only shame is - the anodised blue shifter looks great, but then you have to hide it under the gearlever boot.
By the way, I see it results in a 50% reduction in movement, which I would have thought would imply a 50% increase in effort to change gear. Is that very noticable ??
jhoeven
PostPosted: Tue Feb 01, 2005 10:21 am
[quote="Shaggy"]Are they good? where can you get them e-bay? Recon ill have me one of those.
Ben[/quote]
I didn't know if it would work but I was pleasantly surprised when I got it
installed. As you can see in the manual the distance it takes to move from
1st to 2nd gear was only 50% of the original distance.
I love this new shifter. Because you can shift much quicker, the revs don't
drop as far as they do with the original shifter so you can pull up much
faster :twisted:
This item should come stock if you'd ask me.
Greetz
PostPosted: Tue Feb 01, 2005 11:33 am
Where did you get yours?
jhoeven
PostPosted: Tue Feb 01, 2005 11:39 am
[quote="Smotter"]Excellent guide - very clear !
By the way, I see it results in a 50% reduction in movement, which I would have thought would imply a 50% increase in effort to change gear. Is that very noticable ??[/quote]
You are correct about the bleu color of the stick but you don't wanna drive
without the gearlever boot, that would look like your car isn't finished or
something.
you do have to make a bit more effort to change gear but because there
is a bearring (I hope that is the correct english word) instead of a plastic ring 9stock) the shifting doesn't need a lot more effort than it does in your car now.
[b]At shaggy:[/b]
I got mine at www.r-performance.nl but your local dealer must be able
to order it from a TWM supplier.
It cost me 129 euro.
greetz.
PostPosted: Tue Feb 01, 2005 11:46 am
what 90 pounds for a bent bit of metal!!
think I might just cut mine down LOL
Do you recon any of these will fit??
http://search.ebay.co.uk/mazda-short-sh ... ageZsearch
jhoeven
PostPosted: Tue Feb 01, 2005 1:44 pm
[quote="Shaggy"]what 90 pounds for a bent bit of metal!!
http://search.ebay.co.uk/mazda-short-sh ... ageZsearch[/quote]
Hi Shaggy,
The shifter for the 323F also fits on the MX-6 (tried that myself) so the
MX-6 shifter should also fit on the 323F.
However I don't know if the length of the shifter below the pivotpoint is diferent from mine so I don't know how that will react.
The length below the pivot point is what counts, so sawing it of won't have the same effect.
Greetz
fil_auto
PostPosted: Tue Apr 19, 2005 2:25 pm
is this it?!
http://www.jeroentje.nl/index.php?page= ... id=3015060
Phil
jhoeven
PostPosted: Tue Apr 19, 2005 2:29 pm
[quote="fil_auto"]is this it?!
Phil[/quote]
Yup, I've got that same one. Are you gonna try one out yourself?
Greetz
fil_auto
PostPosted: Tue Apr 19, 2005 2:36 pm
Have been thinking about it for ages and after looking through your guide am quite tempted!
Will concentrate on getting the car fully serviced and through the MOT first.....
... definitely fancy one of these though! Will keep you posted...
thanks and ttfn Phil 8)
jhoeven
PostPosted: Tue Apr 19, 2005 2:54 pm
Cool. If you're able to handle tools it shouldn't be very difficult.
When I made the manual it was my first time installing one of those
and I didn't find it very hard to do.
Good luck with the MOT and have fun fiddling with the shifter :D
Greetz
PostPosted: Tue Apr 19, 2005 3:16 pm
that looks pretty cool....
Is there any one who can translate this guide into English?
jhoeven
PostPosted: Tue Apr 19, 2005 3:20 pm
[quote="tucker101uk"]that looks pretty cool....
Is there any one who can translate this guide into English?[/quote]
Just a sec. It has to be around here in english, i'll try and find it fot ya.
Here you are:
[url]http://www.home.zonnet.nl/jhoeven/jeroen/Handleiding/Short-throw-shifter.pdf[/url]
Greetz
fil_auto
PostPosted: Tue Apr 19, 2005 3:27 pm
Fan(bloody)tastic! :D
jhoeven
PostPosted: Tue Apr 19, 2005 3:29 pm
Yeah well sorry about that, I thought I already posted the english version.
Please forgive me if there are gramatical errors in the manual, my
english isn't perfect and I don't know most english names of certain
tool.
Greetz
fil_auto
PostPosted: Tue Apr 19, 2005 4:04 pm
Relax.... your English is plenty good enough.... and is a shitload better than my Dutch! :D
PostPosted: Tue Apr 19, 2005 7:11 pm
Damn, so THATS where i saw it :oops:
Cracking guide chap, i'm gonna have me one of these before Japfest :)
It does fit the 1.5 right [-o<
PostPosted: Tue Apr 19, 2005 7:18 pm
Just emailed jeroentje re 1.8/1.5 fitment......
PostPosted: Tue Apr 19, 2005 7:28 pm
Bloody hell, that was quick, and a BIG up to Jam 4 de translate :)
It fits all models YAAAAAAY :lol:
JAM
PostPosted: Tue Apr 19, 2005 7:54 pm
No worries Fella :wink:
PostPosted: Thu Apr 21, 2005 6:33 pm
Nice one fella....
PostPosted: Thu Apr 21, 2005 7:17 pm
Ok, not having much success getting hold of Jeroentje to buy this thing!!!!
There doesn't appear to be any online buying on their site either!!
Got fast reply to start but, i've had no reply to the last couple of mails.
I'll keep you posted 8)
PostPosted: Thu Apr 21, 2005 7:21 pm
I think I've seen these on eBay? :o
PostPosted: Thu Apr 21, 2005 7:32 pm
Got a link chap?
PostPosted: Thu Apr 21, 2005 7:34 pm
I'll look!
Nope, sorry found the same ones as Shaggy :(
PostPosted: Tue Apr 26, 2005 1:49 pm
Found this if anyones interested, dunno if it fits but sounds like it might!!!!
http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=33736
PostPosted: Tue Apr 26, 2005 1:54 pm
And this if you don't fancy purple and don't mind paying for it ;)
fil_auto
PostPosted: Tue Apr 26, 2005 1:57 pm
Nice one Andy - will look into this! 8)
PostPosted: Tue Apr 26, 2005 2:22 pm
This doesn't appear to have the fitting kit like the otherone, presumably you re-use the stock fittings, like the price tho!!!
