Club323F • View topic - Remote Central Locking
It is currently Mon Nov 09, 2026 6:13 am
dragon666
 Post subject: Remote Central Locking
PostPosted: Thu Jan 06, 2005 8:42 pm
Hi,
I have a 1996 323f 1.5 GLX and I was fed up of not having remote locking like my last car so I bought a Microscan SCL3000 keyfob thing that can attach to the central locking. I have looked at the guides and think I know which wires to connect but I have no idea were to look for the relays on the car. Does anyone know were the central locking is located in the car? Also do you know if the Haynes manual that says 323 but not 323f actually covers the fastback?
Thanks for your help
Mike
PostPosted: Thu Jan 06, 2005 9:27 pm
My Haynes manual is called "323 & Protege" and does cover the fastback (i.e. 323F) - only problem is it's American spec so the dashboard and stuff is backwards ...
JAJC82
PostPosted: Thu Jan 06, 2005 10:11 pm
I fitted a Sparkrite alarm unit to mine and then added on the Central door locking interface.
I phoned sparkrite and they said that the open/close wires linked to the central locking on the car could be found behind the lower kick panel on the passenger side on the car. The wires that you need to look for are green/red and green/white. I attached the wires from the interface and it all works fine.
I expect that it should be the same for all alarms. Hope this is some help, let me know if you need any more info.
PostPosted: Fri Jan 07, 2005 7:54 am
Just out of interest - I have a Cat4 Wolfguard alarm (SA Manufacturer) with a two stage remote locking interface - press once to open the driver's door and a second time to unlock the rest - does yours do this too ?
JAJC82
PostPosted: Fri Jan 07, 2005 12:26 pm
When I press the remote all doors open at the same time and then press the same button again and they all lock. It is a simple alarm but it was easy to fit and works well.
dragon666
PostPosted: Fri Jan 07, 2005 6:29 pm
Thanks for your help, hopefully I'll have the time to do the work.
Users browsing this forum: No registered users and 30 guests
