Club323F • View topic - Crappy Aerial
It is currently Fri Nov 06, 2026 9:42 pm
col4luke
 Post subject: Crappy Aerial
PostPosted: Mon Dec 02, 2002 9:31 pm
Hi all, this is my first post to the group, hope someone can help.
Any ideas how to get to the electric aerial without totaly dismantling the boot interior. The aerial did work only half heartedly when I bought the car 2 weeks ago but now refuses to retract at all, it makes all the right noises but refuses to make an appearance. 96 1.5 GXi by the way.
Guest
PostPosted: Mon Dec 02, 2002 10:02 pm
You have to remove the side panel, it is held on by clips so you will have to remove them all, from behind the rear seat as well, not too difficult.
col4luke
PostPosted: Mon Dec 02, 2002 11:17 pm
Thanks, I'll give it a looking at.
Arnie
PostPosted: Tue Dec 03, 2002 12:09 am
That previous message was from me, I did not get logged on automatically. It seems to work when it feels to work.
I dismantled my boot but I have a LAntis which might be slightly different in that it has platic trays which all clip together. But it is the same side panel. Aerial will be easily accessible once this is removed.
Guest
PostPosted: Mon Jan 06, 2003 11:34 pm
i bought an new aerial cos some tw@t was of his head on sat'day night so he decided 2 snap me aerial in half (it cost me £30+ from mazda). when i do see him again im gonna wack him round the head with a bar!
do N E 1 kno if is easy 2 fit ? i can take the boot trim out & access it but from there......................
halfcore667
PostPosted: Wed Jan 08, 2003 7:32 pm
if it's just the mast that you've bought, unscrew the ring from around the top of the areial, switch the radio on so the aerial goes up (this will push the old mast out) swap the metal collar off the old aerial on tot eh new one, feed the white plastic cable down into the aerial, get someone to switch the radio off and twist the cable around until the motor pulls it in, whem the pole has gone in to the motor refit the metal ring and operate the aerial again.
