Club323F • View topic - Hi all - new member - Q on replacing rear hatch/screen on BA
It is currently Wed Nov 04, 2026 10:05 pm
MarkSYD
PostPosted: Fri Aug 04, 2017 8:15 am
Hi all, greetings from Sydney.
Does anyone know how to remove + replace the rear windscreen on a BA hatchback? And then reconnect the screen's heater element?
Or: If I replace the entire hatchback, how to remove and re-feed the electric cables into the replacement?
I have a complete spare hatchback - but the cabling was cut nearer to the hatch, than to the roof - so I expect that connecting the cabling will be difficult!
MANY THANKS in advance!
PostPosted: Fri Aug 04, 2017 8:44 am
Welcome to the forum. I think I've seen this done before so have a search through :thumbleft:
MarkSYD
PostPosted: Fri Aug 04, 2017 8:54 am
Many thanks Lerch! Much appreciated!
PostPosted: Fri Aug 04, 2017 2:23 pm
Hi MarkSYD, greetings from Castle Hill!
Well actually Canberra, the car's in Castle Hill. :)
It looks like you can replace the window if you wish, see the following threads/posts (unfortunately the pics have gone AWOL):
[url=http://club323f.com/forum/viewtopic.php?f=18&t=56712&p=724284&hilit=rear+window+replacement#p724284]Post 1[/url]
[url=http://club323f.com/forum/viewtopic.php?f=14&t=52957&p=717952&hilit=rear+window+replacement#p717952]Post 2[/url]
Alternatively you could have a look under the trim on the rear hatch- it may be that the hatch has its own wiring loom and there are connectors for the car's loom just inside the top panel of the hatch- apparently there's a connector there for the high mount rear stop LED/light. If this is the case you can simply unplug your car's loom swap the hatch over and reconnect the car and hatch looms.
Good luck, let us know how it goes,
[b]Patrick[/b]
Users browsing this forum: Google [Bot] and 17 guests
