Club323F • View topic - Need help identifying more components
It is currently Sat Nov 07, 2026 11:32 am
harboged
PostPosted: Mon Mar 16, 2015 11:02 pm
Hi again,
Some questions about my 323f 1.8 dohc -90.
In the first photo: what is this thing that the yellow arrow points at? It's located on top of the engine.
In the second photo: what is this thing that the red arrow is pointing at? It is supposed to be connected to the thing in the first photo but the plastic pipe has snapped.
PostPosted: Mon Mar 16, 2015 11:09 pm
Vics valve isn't it?
harboged
PostPosted: Tue Mar 17, 2015 12:32 pm
Yes, that makes sense. Thanks!
So with the pipe snapped off, does it mean the valve is always open or always closed?
Since I will only race the car, the engine will mainly work in the upper revs. I assume it's preferable to keep it open then?
harboged
PostPosted: Tue Mar 17, 2015 1:42 pm
OK, I answer my own question :) Looking at this photo and knowing that there will be no vacuum, I guess it will be open all the time.
However, for my purpose - the race track. Should I leave it as it is and not bother to fix it? Do people actually feel any difference with the VICS working or not working?
PostPosted: Tue Mar 17, 2015 2:11 pm
I would say, if you're not going to fix it, try taking it for a drive as is, then hold it open with a cable tie or something, then repeat the same drive. Leave it in whatever position you prefer :)
harboged
PostPosted: Tue Mar 17, 2015 2:28 pm
[quote="Marc S"]I would say, if you're not going to fix it, try taking it for a drive as is, then hold it open with a cable tie or something, then repeat the same drive. Leave it in whatever position you prefer :)[/quote]
True! :)
Anyone know the part number for the three-way solenoid valve?
