It is currently Wed Sep 16, 2026 1:02 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 30 posts ]
PostPosted: Tue Apr 03, 2007 8:46 pm
Some pictures of how I joined the bottom half of a Renault Laguna 94 to 98 front bumper to the 323F BG front bumper.
1. You need to remove the front lower part of the 323F bumper, from the fog light holes inwards. Leave the side parts, these provide a fixing point.
2. The Laguna bumper should be cut so that the number plate part is removed, and continued straight along both sides.
Measure 4 or 5 times, and cut once!!!
If your not too sure, or confident, then leave some on for trimming.Its easier to trim bits off than try to add bits on again.
3. I used super epoxy resin glue and fibreglass resin to join it all together. But there is better glues on the market.
4. I also used a variety of stainless nuts and bolts to join everything. Most fixing will be done behind the number plate, but you also need a bit of strength at the sides.
5. Fix in the wheelarch part with a couple of long rivets, or low profile coach bolts.
zx6r
PostPosted: Tue Apr 03, 2007 9:12 pm
Nice guide Neil - Was a nice car as well tho - shame.
mazz
PostPosted: Tue Apr 03, 2007 10:59 pm
aah Neil you STAR! :D
Club 323 swindon division :)
Fleet of 8 & still going strong 8)
Nes, Ghost, White shite 1, White shite 2, Messiah, Kgb, Bug & Riot
www.reefgeeks.co.uk
Lantis
PostPosted: Wed Apr 04, 2007 12:10 am
that to me is very impressive! its simply amazing how ppl come up with ideas ones such as this. excellent!
whitedragon
PostPosted: Wed Apr 04, 2007 1:44 pm
I'm just happy that's it's here so I can convert!
Lex
PostPosted: Wed Apr 04, 2007 1:48 pm
Thanks for putting it on! I guess if I do get a BG then I'll have to give this a try. BOOKMARKED!
aaron_323BG
PostPosted: Thu Jun 14, 2007 2:00 am
doing this... have too!
nice guide! :D
Guest
PostPosted: Thu Jul 24, 2008 11:06 pm
great job!!
a few questions thow
1 - how did you seal the gap between the bumpers?
2 - what kind of net did you use for the bottom part and how did you
attached it to the bumper?
PostPosted: Fri Jul 25, 2008 10:47 pm
The gap between the bumpers is sealed with seam sealer, which is paintable.
Bumper is held together with stainless steel nuts and bolts.
2 behind the number plate, one above each fog light hole, and one at each wheelarch.
The mesh is just racing mesh/aluminium from Ebay. :wink:
Guest
PostPosted: Sun Jul 27, 2008 4:12 am
tnx for the help!
i'm in search for a laguna :)
and one last question, which tool did you use to cut the bumpers?
PostPosted: Sun Jul 27, 2008 9:47 pm
Electric jigsaw.
Measure 15 times, cut once. :wink:
Guest
PostPosted: Mon Jul 28, 2008 3:06 am
Neil F wrote:
Electric jigsaw.
I will!!! :)
I've found a bumper, gonna get it tomorrow. it has a little dent by i think ill be able to fix it...pictures soon....
Neil F, tnx once again!!! u rock!
BadEd
PostPosted: Sat Aug 23, 2008 9:24 am
in the middle part (behind the number plate) did you cut out the vertical plastic bits before you've putted the mesh?
paul323f
PostPosted: Sat Aug 23, 2008 4:06 pm
nice :D
PostPosted: Sat Aug 23, 2008 8:54 pm
Yes, I cut the vertical parts out, and left the long horizontal bit. :wink:
platinium
PostPosted: Fri Oct 17, 2008 1:21 pm
Hallo!
Does anybody knows if the Laguna spoiler will fit 323f BA?
platinium
PostPosted: Thu Oct 23, 2008 9:50 am
Anybody?
Ben_P
PostPosted: Thu Oct 23, 2008 9:55 am
No idea, you'll have to try it for yourself i think.
mazz
PostPosted: Thu Oct 23, 2008 9:58 am
well i know with a bit of work the BA front bumoper can fit the BG.
makes it look like a ford prob mind you.
so i cant see why the BG front bumper cant fit the BA, will ned some work to fit it.
an once its fitted then i guess you can do the conversion.
should be intresting if you do this and pull it off well!
www.reefgeeks.co.uk
PostPosted: Thu Oct 23, 2008 4:13 pm
You can pretty much make anything fit anything, within reason, if you put enough effort into it.
Go to the scrappy and take a few measurements.
I personally don't see why you would want to fit a laguna front to the BA anyway....... I reckon it would look shit. :wink:
platinium
PostPosted: Fri Oct 24, 2008 7:53 am
What about this one? Isn't it from laguna bump spoiler? If it's so, I think it will look awesome. And, what else front spoiler will fit the BA, I'm really interested? :bounce:
2Beck
PostPosted: Sat Nov 22, 2008 4:10 am
pics missing :(
PostPosted: Sat Nov 22, 2008 6:03 pm
All the pix are stil lthere mate. :wink:
That BA is a Mazdaspeed front lip I think.
2Beck
PostPosted: Sun Nov 23, 2008 9:59 pm
wow. its back now.. wasnt there when i posted. hehe. great tut man. :)
A L 3 X
PostPosted: Sun Nov 23, 2008 10:10 pm
platinium that is the Mazdaspeed A-Spec lip
The laguna front splitter will fit on a BA as RHRH is planning to do:
the cupra splitter and original V6 splitter will also fit....
vam
PostPosted: Mon Nov 24, 2008 2:11 pm
sweet!! love the bumper..
AlxBG
PostPosted: Mon Nov 24, 2008 2:16 pm
griffs BA had a laguna splitter too
ds323f
PostPosted: Thu Jan 22, 2009 4:34 pm
if only i have a jigsaw to slice that laguna bumper. hihi. i saw one laguna in the philippines and still the car is in condition to drive.
good thing i have fabricated an OE chin for the 323f bg (astina) at the nearest fiberglass shop.
lewp91
PostPosted: Sun May 03, 2009 9:10 pm
i really like that chin... any chance you can show how???
PostPosted: Fri Jul 19, 2013 8:19 am
My Car: Mazda 323F GTR
can this be locked due to spam?
The 323F GTR 1.8 Turbo
