...or "Why Daylight is ALWAYS Better than Artificial Light."
So the Mazda 3 needed new suspension bits after 220k km. Inspired by you lot (yes, really!
) and decided I should try to tackle this job myself. And also I wanted to try before I really get too old to do something I should have tried 20+ years ago.
I mean, I got prepared. Read manuals. Bought equipment. Bought parts and sought advice from suspension specialists, mechanics, workmates, etc, etc. Yet I knew something would go somewhat ludicrously wrong, somehow, at some point.
That happened last night as I was attempting to remove the rear shocks. I needed to remove the lower shock mount bolt and I could see the flanged nut on the end. Now this wasn''t in some dim background, I had a 150W halogen floodlamp on one side and a 20W fluoro work lamp on the other. I got the 17mm socket and ratchet on, it was too tight as expected. I'd sprayed penetrant on them previously so I got the breaker bar out,but they wouldn't budge- more penetrant, wait, try again- solid as a rock on both sides of the car.
I had an inkling something wasn't quite right, it was late and cold so rather than break something I decided to leave it 'til the morning. I've found before daylight and a break can shed a totally different light on things!
In the meantime I reviewed an Youtube of the process and noted the mechanic removed the bolt from the other side, not the nut. Hmmm...
Come the morning...come the answer! As soon as I looked I knew what the problem was as the daylight cast aside any shadow of a doubt (more bad puns). The nut was there... pity it was part of the mount! I'd have to rotate the whole car to get it to move...I acquiesced and tried removing the bolt which immediately complied with my efforts.
So why on Earth would a flanged nut be used for a threaded hole?? I can only assume whoever was designing the mount needed a threaded hole, and the quickest and nearest to be found was a CAD file of a flanged nut which was duly cut-n-pasted into position...Nuts to that!!!
[b]Patrick[/b]
