Club323F • View topic - After market steering wheel
It is currently Wed Nov 04, 2026 11:41 pm
salmirza
PostPosted: Mon Dec 01, 2014 8:33 pm
Hi all was thinking about getting an after marker steering wheel
how easy is it to replace and kill the airbag light?
One like this or a deep dished one
http://m.ebay.co.uk/itm/301383971908?nav=SEARCH
Ta
sneakz
PostPosted: Tue Dec 02, 2014 12:15 am
Just fit a resistor in betwee that matches the resistance of the airbag itself. I believe there is how-to here somewhere that states which one you need. Search function will do the job I suppose :D
PostPosted: Tue Dec 02, 2014 9:55 am
I'm sure there is a guide somewhere, but yeah it's very very simply. Buy any Mazda boss kit (they're all interchangable), then buy your aftermarket wheel.
You'll need a 3.3ohm resistor (19p at Maplin) to disable the airbag warning light. There's a 3 pin connector behind the steering wheel, wiring wrapped in bright yellow insulation. One of those wires is green with a red stripe - that's your horn wire. The other two are the airbag, the resistor must go in between those. The horn wire you should make some sort of contact with the brass ring on the back of the boss kit, then plug your horn button into the connector on the boss kit, job done :)
Hardest part is removing the old wheel - 10mm bolts on the back of the wheel to release the airbag (disconnect battery first!), then a 21mm nut in the centre to release the wheel. Don't remove this nut fully - loosen it most of the way, then keep yanking on the wheel until it comes off. If you remove the nut fully, chances are you'll twat yourself in the face with the steering wheel when it comes off :lol:
salmirza
PostPosted: Mon Dec 08, 2014 2:40 am
[quote="HughieW"]I'm sure there is a guide somewhere, but yeah it's very very simply. Buy any Mazda boss kit (they're all interchangable), then buy your aftermarket wheel.
Hardest part is removing the old wheel - 10mm bolts on the back of the wheel to release the airbag (disconnect battery first!), then a 21mm nut in the centre to release the wheel. Don't remove this nut fully - loosen it most of the way, then keep yanking on the wheel until it comes off. If you remove the nut fully, chances are you'll twat yourself in the face with the steering wheel when it comes off :lol:[/quote]
Legend.. a billion thanks
Users browsing this forum: Bing [Bot] and 14 guests
