[quote="benidormdale"][quote="nighthawk888"][quote="Marc S"]I don't think Philips make an aftermarket fit HID kit...at least they didn't a few years ago, and had no intention of doing so
[/quote]
I am not so sure about your country but in Malaysia we do have philips selling HID kit. If the bulb is switched to the High beam reflector it seem fine. suspecting the lens is not transparent enough for the lights to projected out fully.[/quote]
Sorry mate but are you talking about a BA here as you mention switching the bulb to HIGHBEAM ???? HIGHBEAM does not use the projector light, it uses a standard reflector light with glass lens.
To me you are putting across main and high beams in the one bulb (like old bulbs)?? BA's have a bulb for each light ,as you state when you switch to high beam it seams fine. I have HID's fitted both main and high on my 1.5 and the road lights up when high beam is on (like a football pitch), however on Lexi (my V6) she only has them fitted to dipped (main beam) and has standard halogens on high beam, when HIgh beam is on it really makes no differance as the HIDs are brighter, I only seem to get a sort of little yellow glow above the bright white which the HIDs are projecting. So this makes me think your talkng about one bulb which has both functions as the BA has two bulbs, either H3 &H1 or both H1.
I and including all members who have done the conversion have saw massive improvements in lighting.
I have 55w ballest which are better that 35w and provide 25% more light, but even 35w are 100% better than standard
Halogen bulbs as I kniw as my lasted BA has standard halogens fitted and I cant see f*** all.
I also have never heard of philips HIDs and if they are new then I would suggest they are shit.
Try sone other HIDs.
As for the projector kens there is nothing wrong with the BA lens and they produce they same light as most new projector lensed cars. I know this as I have fannied about with the lights and a set off Audi 2010 A4 lights when I was making my DRL setup.
BA projector are fibe , must be the philips kit as all members have had no complaibts about their kits.
Sorry to say but philips are shit anyway as I have had had bad experiences with their products. Same goes for Panasonic even tho they have nothing to do with auto stuff execpt stereos. Same with philips cone to think of it when have tgey dealt with car stuff except bulbs, which we ate discussing. Well enough said because their domestic bulbs are shit.
Get a decent kit mate and you will see the difference[/quote]
Thanks for the long reply. HID are definitely better than stock halogen bulb, but i wish to improve it further more. Going to try a set of koito ballast and see if the output is much better. Mine is 35w, heard 55w is much better but it is hard to find it here.
