It is currently Wed Sep 16, 2026 2:53 pm
KjaLLe
PostPosted: Mon Feb 14, 2011 4:18 am
An idiot drove into my car when I was at midwife training with my girlfriend and ran away from it, so now I am standing here with a smashed bumper, and must therefore having it painted.
I'd like to paint my side mirror caps and rear spoiler, when I anyway going to the paint shop.
Since the spoiler is a bit white on the top, and my right side mirror is uncoated plastic color, as this is replaced, gues it was ran off before my time.
I expect maybe myself removing the bumper, to keep costs down and must anyway having corrected a bumper bracket if such one exists(?), as the bumber is pushed approx. ½ -1 cm under the rear light.
But now my question is whether mirror caps can be removed, or are they painted on? The same with the spoiler, can this be removed without problems?
Misspellings are free today :)
TheMAN
PostPosted: Wed Feb 16, 2011 5:38 am
are your mirrors electric or manual adjustment? the manual adjustment mirrors won't look right after painted because its is actually a very different design from the painted electric mirrors
the unpainted mirrors uses a single piece housing with textured plastic all around... the painted mirrors have smooth plastic on the painted portion and is a separate part that snaps into the actual housing, which is black textured plastic
they are made by different suppliers too
KjaLLe
PostPosted: Thu Feb 17, 2011 1:16 pm
Thanks for the reply.
Both my mirrors are electric and heated, but checked anyway after you wrote - and you're right.
My right hand mirror (which I presume has been replaced) was more rough and dull on the surface, while my left mirror is completely smooth.
So I went to the local auto recycling and bought an other mirror cap, which was smooth and painted. They have sadly non black painted, but now the painter then get 2 identical mirror caps and paint :)
At the auto recycling I also found out how to remove the mirror caps.
So now only one question left: The rear spoiler, can this be removed without problems?
PostPosted: Thu Feb 17, 2011 1:21 pm
Yes mate, screws on from inside the bootlid :)
Yes. Ive removed mine afew times. Lift your tailgate and you'll see rubber bungs, remove them and this will reveal fixing nuts. Undo them and pull the spoiler off :thumbright:
The Mighty BeeJay
PostPosted: Thu Feb 17, 2011 1:22 pm
snap! I called it first so I win :)
The Mighty BeeJay
KjaLLe
PostPosted: Thu Feb 17, 2011 5:01 pm
Sounds easy, many thanks for the help guys.
Then I can book an appointment with the painter, next week :)
Cali
PostPosted: Thu Mar 22, 2012 8:23 pm
Can you explain how to remove the mirror caps?
KjaLLe
PostPosted: Mon Mar 26, 2012 12:30 am
You have to remove the glass to get the cap off.
Remove the glass by pushing it all the way in, in the side facing the door, now you schould be able to get a couple of fingers behind the glass, an gently pull it out. The glass is hold by 4 clips in the center of the glass so try to pull as close to the center as possible, so that the glass will not crack..
When the glass is off the cap is simply hold by 4 clips, that you need to push trought the housing, again be gentle these clips will easely crak off.
Users browsing this forum: No registered users and 47 guests
