Club323F • View topic - Engine Torque Specifications - keep
It is currently Tue Nov 03, 2026 10:46 pm
PostPosted: Fri Mar 11, 2005 9:30 am
[quote="Smotter"]
Torque Specifications Ft-lbs (unless otherwise indicated)
Camshaft sprocket bolt.................... 36 to 45
Camshaft thrust plate bolt (1.6L SOHC).... 69 to 95 in-lbs
Crankshaft pulley bolts................... 109 to 152 in-lbs
Crankshaft sprocket bolt.................. 116 to 123
Cylinder head bolts
1.6L and 1.8L SOHC, and 1.8L DOHC (through 1998) .. 56 to 60
1.5L DOHC, and all engines from 1999 on
Step 1................................... 12-16
Step 2.................. ................ Tighten an additional 85 to 95 degrees
Step 3................................... Tighten an additional 85 to 95 degrees
End plate bolts........................... 69 to 95 in-lbs
Engine mount bolts/nuts
No. 1 engine mount bracket bolts to engine 50 to 68
No. 1 engine rubber mount through-bolt.... 48 to 65
No. 1 engine mount to crossmember nut..... 50 to 65
No. 2 engine mount bracket bolts to engine 28 to 38
No. 2 engine mount bracket to crossmember. 28 to 38
No. 3 engine mount bracket to engine...... 55 to 77
No. 3 engine mount bracket small bolts ... 14 to 16
No. 3 engine mount bracket nuts........... 69 to 83
No. 3 engine mount brackets large bolt.... 50 to 68
No. 4 left (driver's side) engine/transaxle bracket-to-transaxle nuts ............. 50 to 68
No. 4 left (driver's side) engine/transaxle bracket-to-frame bolts.................. 32 to 44
Exhaust manifold bolts/nuts
1.6L and 1.8L SOHC ....................... 12 to 17
1.5L DOHC, 1.6L DOHC and 1.8L DOHC
Through 1998.............................. 28 to 34
1999 and later ........................... 14 to 21
Exhaust manifold heat shield bolts/nuts.... 69 to 95 in-lbs
Exhaust pipe bracket bolts................. 27 to 38
Flywheel cover bolts
1.6L and 1.8L SOHC ....................... 27 to 38
1.5L and 1.8L DOHC........................ 48 to 65
Flywheel/driveplate bolts.................. 71 to 76
Intake manifold bolts ..................... 14 to 19
Oil pan Main Bearing Support Plate (MBSP) bolts... 12 to 15
Oil Pan Stiffener bolts (models with separate oil pan)... 27 to 38
Oil pan bolts.............................. 69 to 95 in-lbs
Oil pump bolts ............................ 14 to 19
Oil pump strainer.......................... 69 to 95 in-lbs
Rear cover screws.......................... 69 to 95 in-lbs
Rocker arm shaft bolts (1.6L and 1.8L SOHC) 16 to 21
Tensioner pulley bolt
1.6L and 1.8L SOHC........................ 14 to 19
1.5L and 1.8L DOHC........................ 28 to 38
Timing belt idler pulley bolts
1.6L and 1.8L SOHC ........................ 14 to 19
1.5L DOHC, 1.6L DOHC, and 1.8L DOHC....... 28 to 38
Timing belt cover bolts ................... 70 to 95 in-lbs
Valve cover bolts
1.6L and 1.8L SOHC ....................... 43 to 78 in-lbs
1.5L DOHC................................. 61 to 95 in-lbs
1.8L DOHC
Two bolts at end of valve cover............ 69 to 95 in-lbs
Screws on top of valve cover............... 43 to 78 in-lbs
Water pump pulley.......................... 70 to 95 in-lbs
PostPosted: Fri Mar 11, 2005 10:58 am
And the head bolt tightening sequence (reverse sequence for removal ...)
[img]http://www.geocities.com/smotter.geo/Temp/HeadBoltSeq.jpg[/img]
$uPaFLy V6
PostPosted: Tue Sep 25, 2007 8:01 am
hi, any chance of the front rocker bolt sequence for the v6 KF? plz lz plz can't seem to find it anywhere.
Found one on astina gt site that is rather confusing. there is no pics, the squeunce i can't make sense of it!
http://www.astinagt.com/forums/showthread.php?t=6131 :S can u work it out?
maylander739
PostPosted: Tue Sep 25, 2007 9:22 am
rocker cover bolt sequence? surely there isn't one because the bolts are so loose?
PostPosted: Tue Sep 25, 2007 11:32 am
[quote="$uPaFLy V6"]hi, any chance of the front rocker bolt sequence for the v6 KF? plz lz plz can't seem to find it anywhere.
http://www.astinagt.com/forums/showthread.php?t=6131 :S can u work it out?[/quote]
i'll see if it's in my book tonight - wont be able to post a reply (either way)till tomorrow :thumbright:
PostPosted: Tue Sep 25, 2007 11:33 am
actually, dan (gogobroom) probably knows the sequence off by heart
IOW323F
PostPosted: Tue Sep 25, 2007 12:44 pm
It's the same principle with all heads.
Working out in a circle so you do not warp it, especially during tightening.
[img]http://img.photobucket.com/albums/v637/iow323f/HeadBoltSeq.jpg[/img]
PostPosted: Tue Sep 25, 2007 6:11 pm
There is no sequence for the rocker cover, but, its not a bad idea to follow the circle method as Nick suggests, put them all in finger tight, then nip up in circle fashion :D
PostPosted: Tue Sep 25, 2007 7:05 pm
The torque on the BG rocker cover was only 8lb/ft.
Not much, just enough to seal the rubber gasket. :wink:
$uPaFLy V6
PostPosted: Wed Sep 26, 2007 3:27 am
Thats intresting ill just go the swirl method an i should be ok then :) tighten back over to bout 8-10nm with torque an hope for best when i turn the key :P
danklc
PostPosted: Wed May 30, 2012 9:27 pm
does anyone know the correct sequence and torque settings for when re fitting the cam shafts. i have a 1.8 NA BA 1997 and need to know the retainer/carrier torque settings so i do not over tighten them. thanks
