Club323F • View topic - Screenwashers
It is currently Mon Nov 09, 2026 4:20 pm
hohohobigol
 Post subject: Screenwashers
PostPosted: Wed Jul 07, 2004 7:04 pm
My one of my screenwashers doesnt appear to be working, the motor appear to be fine (dont appear to be making obscure noises etc) but i think there might be a hole in the tubing or a blockage of some sort in the tube.
How do I get the screenwashers out? There appears to be a big kind of casing under the bonnet. I'll need that off. Not got a clue how to do it though. Any help?
wai.cheung01
PostPosted: Wed Jul 07, 2004 7:46 pm
You could try using a pin on the end of the washer jet. It won't hurt it and may just displace the limescale that appears to be blocking the jet.
Is it the back washer?!
I had that problem and couldn't fix it with the 'pin' method and eventually had to take it to the dealers to have then take a look at it.....
Turns out that the back washer has a seperate resevoir under the floor of the boot on the driver's side....! :oops:
hohohobigol
PostPosted: Thu Jul 08, 2004 8:09 pm
Its the front passenger side jet.
Tried cleaning with the pin, again no luck.
Anyone know how that frame under the bonnet comes off so i can get stuck into the thing?
fil_auto
PostPosted: Fri Jul 09, 2004 10:26 am
If your referring to the grey looking blanket, underside of the bonnet ( heat absorbent, I think )
Mine's held in with loads of plastic pins all the way round, just have to prise them off. you can then get to the pipes for the squirters.
ttfn
Phil :D
hohohobigol
PostPosted: Sun Jul 11, 2004 2:52 pm
How does it go back on?
Want to make sure before i pull it off.
tucker101uk
PostPosted: Mon Jul 12, 2004 9:39 am
poke the clips back in the holes!
They are just like grommit type things i think.
