Club323F • View topic - How do you fit a zxi splitter
It is currently Thu Nov 12, 2026 12:37 am
maylander739
PostPosted: Thu Jan 19, 2006 3:26 pm
How do you fit a zxi splitter? Do you have to take the bumper off? Does it fit a certain way?
I know you've done this Rich, so any pointers would be great
[img]http://i30.photobucket.com/albums/c321/maylander739/sig2.jpg[/img]
richardesty
PostPosted: Thu Jan 19, 2006 5:59 pm
Jach the car up, remove some plastic locating tabs off the slitter, fix the three bits together, line it up to the car then fix with self tappers.........then don't over run high kerbs when parking :thumbleft:
maylander739
PostPosted: Thu Jan 19, 2006 6:01 pm
line up the car?? how do you line it up, does the inside of the splitter go perfectly with the inside of the bumper?
JAJC82
PostPosted: Thu Jan 19, 2006 6:02 pm
I just got the car up on the ramps and used small bolts through the holes already in the splitter and drilled holes up through the bumper. It didn't take long but was a 2 person job to hold it in place and drill at the same time. Also make sure you use washers so the bolts don't pull through.
I don't know if that was the easiest way to do it but it worked for me.
???Have you managed to find a splitter???
James
maylander739
PostPosted: Thu Jan 19, 2006 6:03 pm
only have one jack in york, so might find some sort of a ledge. Either that or its taking off the bumper
maylander739
PostPosted: Thu Jan 19, 2006 6:05 pm
[quote="JAJC82"]
[/quote]
Maybe :roll:
richardesty
PostPosted: Thu Jan 19, 2006 7:27 pm
[quote="maylander739"]line up the car?? how do you line it up, does the inside of the splitter go perfectly with the inside of the bumper?[/quote]
Once you get the three bits together, it's obvious where it lines up - cos it's snugg!
maylander739
PostPosted: Thu Jan 19, 2006 7:28 pm
ok, cheers
richardesty
PostPosted: Thu Jan 19, 2006 7:32 pm
[quote="maylander739"]ok, cheers[/quote]
Yours and JAJC82's ride's are gonna be mighty similar..........
phoenix
PostPosted: Thu Jan 19, 2006 10:54 pm
Is it a new one as advertised by Rich?
or is it a used already one?
and being nosey how much? :bounce:
JAJC82
PostPosted: Thu Jan 19, 2006 11:26 pm
[quote]Yours and JAJC82's ride's are gonna be mighty similar..........[/quote]
So what can I do to make mine that little bit different ;)
I am glad that I got the splitter and only wish I had found one sooner, I do think it makes a big difference to the look of the car.
maylander739
PostPosted: Fri Jan 20, 2006 12:13 am
PM'd
