Club323F • View topic - rear washer not working
It is currently Sat Nov 07, 2026 11:49 am
etee
 Post subject: rear washer not working
PostPosted: Thu Apr 15, 2004 7:31 am
does anyone know how the rear washer is connected? i bought my 95 astina a couple of months ago (so am a bit of a newbie :wink: ) but the rear washer doesn't work. i've tried that "poke a needle in the hole" tip, but still no spray :(
the front washers work fine tho, so i don't think its a problem with the reservoir (it's only the one reservoir right?? :? ). the rear wiper works so i would think the switch stalk is ok... not too sure where to go from here...
thanks for any help :)
Dan
PostPosted: Thu Apr 15, 2004 9:08 am
if you open the boot and take up the carpet covering to the right if you look you will see a washer reservoir...
just have a look around the boot you will see it, make sure its topped up...
etee
PostPosted: Tue Apr 20, 2004 7:29 am
doh... :oops: thanks for that :P
... but... i topped it up but still no spray... :(
i can hear the pump going, so i don't think that has conked out... so i'm thinking it might be a blockage or leak?
does anyone know how the tubing is routed? and how to go about pulling it out to have a look at... :?
Dan
PostPosted: Tue Apr 20, 2004 9:28 am
i had the same problem with the front washers in the winter, i didn't top them up for ages and when i did nothing happened! i guessed it was just like air in the pipe or something!
cos after a while it started working again...
V6GREG
PostPosted: Tue Apr 20, 2004 12:48 pm
...etee, here is a Scan I have done showing you the Route of the Rear Washer Piping...
http://uk.groups.yahoo.com/group/mazda3 ... %20Piping/
V6GREG.
etee
PostPosted: Tue May 04, 2004 4:53 am
thanks for the scan :D i'll give it a try when i find some time and let you know how i go... :wink:
